[fdo-users] ODBC MS SQL Server error feature on check in after editing
Jackie Ng jumpinjackie at gmail.com
Sun Dec 13 17:42:15 EST 2009
If you turn on tracing, what SQL statements is the provider trying to
generate for the insert command?
- Jackie
kalmy wrote:
> Jackie,
> I don't think is about string, look for this second picture I made  a new
> table without string, I think is a problem with odbc FDO provider because
> with mdb access file works.
> http://n2.nabble.com/file/n4150358/ODBC%2Berror%2B2.jpg ODBC+error+2.jpg
> I creat a simple table with ID, and X, Y all numeric.
> The check in failed.
> Kalmy
View this message in context: http://n2.nabble.com/ODBC-MS-SQL-Server-error-feature-on-check-in-after-editing-tp4108036p4161429.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
