[fdo-users] ODBC MS SQL Server error feature on check in after editing
Jackie Ng jumpinjackie at gmail.com
Mon Dec 14 04:16:10 EST 2009
>From your screenshot, I assume you're not using the express edition of SQL
Server.
In that case, there should be a SQL Server Profiler installed. Run it and
configure it to watch for T-SQL statements. Run your FDO insert command
again and see what SQL is being fed to SQL Server.
- Jackie
kalmy wrote:
> Can you tell me where/how can I turn on the tracing ?
> Kalmy
View this message in context: http://n2.nabble.com/ODBC-MS-SQL-Server-error-feature-on-check-in-after-editing-tp4108036p4163083.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
