[fdo-users] 3.3.2 Source Files with Unexpected Names
Bob Cave bobc at bluemarblegeo.com
Fri Feb 13 11:23:52 EST 2009
I installed ActivePerl 5.10.0.1004.
I found some other files with 000064 appended to their extensions in the
apache/xml-xalan directory and in Unmanaged/Inc/Fdo.  I just renamed the
files and continued the build and things seem to be OK so far.
Thanks,
Bob
Greg Boone wrote:
> Did you install ActivePerl? If so, which version?
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Bob Cave
> Sent: Friday, February 13, 2009 9:52 AM
> To: fdo-users at lists.osgeo.org
> Subject: [fdo-users] 3.3.2 Source Files with Unexpected Names
> I am building FDO 3.3.2 on Windows.  I have run SetEnvironment.bat to
> initialize the environment, then launched Visual Studio 2005 from that
> command line session so that it will have the environment set up
> correctly.
> While building XercesLib, I got errors saying that various header files
> could not be found:
> xercesc/validators/schema/identity/XercesXPath.hpp
> xercesc/validators/schema/identity/IC_Selector.hpp
> xercesc/framework/psvi/XSComplexTypeDefinition.hpp
> [snip]
View this message in context: http://n2.nabble.com/3.3.2-Source-Files-with-Unexpected-Names-tp2321595p2322103.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
