[fdo-users] Trying to Deploy FDO to Web
surrounded Rob.Sosnowski at itd.idaho.gov
Tue Feb 17 11:06:10 EST 2009
Hello,
I'm using FDO within VS 2008 project (web service) and works fine when run
as localhost on my PC.
I've moved the web service to a production server, copied the FDO bin, lib,
and inc folders to the production server, and set the environment PATH
variable on the server to point to the FDO folders.
When I run the application I get the following error:
System.IO.FileNotFoundException: The specified module could not be found.
(Exception from HRESULT: 0x8007007E)
ANY IDEAS ON WHAT IS CAUSING THIS?  HOW IS FDO SET UP TO RUN ON WEB SERVER?
Thanks.....
View this message in context: http://n2.nabble.com/Trying-to-Deploy-FDO-to-Web-tp2341612p2341612.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
