[fdo-users] Trying to Deploy FDO to Web
surrounded Rob.Sosnowski at itd.idaho.gov
Tue Feb 17 11:40:04 EST 2009
Hi Greg,
No, so if I download Depends.exe, how would I use it to determine the
missing module??
[mailto:ml-user+67529-964960874 at n2.nabble.com]
Sent: Tuesday, February 17, 2009 9:36 AM
To: Rob Sosnowski
Subject: RE: [fdo-users] Trying to Deploy FDO to Web
Have you run depends.exe to try and determine which module cannot be
found?
-----Original Message-----
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2341773&i=0>
[mailto:fdo-users-bounces at ...
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2341773&i=1> ]
On Behalf Of surrounded
Sent: Tuesday, February 17, 2009 11:06 AM
To: fdo-users at ...
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2341773&i=2>
Subject: [fdo-users] Trying to Deploy FDO to Web
Hello,
I'm using FDO within VS 2008 project (web service) and works fine when
run
as localhost on my PC.
I've moved the web service to a production server, copied the FDO bin,
lib,
and inc folders to the production server, and set the environment PATH
variable on the server to point to the FDO folders.
When I run the application I get the following error:
System.IO.FileNotFoundException: The specified module could not be
found.
(Exception from HRESULT: 0x8007007E)
ANY IDEAS ON WHAT IS CAUSING THIS?  HOW IS FDO SET UP TO RUN ON WEB
SERVER?
Thanks.....
View this message in context:
http://n2.nabble.com/Trying-to-Deploy-FDO-to-Web-tp2341612p2341612.html
Sent from the FDO Users mailing list archive at Nabble.com.
fdo-users mailing list
fdo-users at ...
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2341773&i=3>
http://lists.osgeo.org/mailman/listinfo/fdo-users
fdo-users at ...
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2341773&i=4>
This email is a reply to your post @
http://n2.nabble.com/Trying-to-Deploy-FDO-to-Web-tp2341612p2341773.html
You can reply by email or by visting the link above.
View this message in context: http://n2.nabble.com/Trying-to-Deploy-FDO-to-Web-tp2341612p2341829.html
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20090217/e39bfe85/attachment.html
More information about the fdo-users mailing list
