[fdo-users] OGR 3.3 Provider runtime error [SOLVED]
surrounded Rob.Sosnowski at itd.idaho.gov
Tue Feb 17 12:14:52 EST 2009
I'm reading through your post and seems similar to my problems.
Trying to use FDO on web server.  It works fine on my PC (Windows XP) both
from VS 2008 web service I wrote and from localhost when I call the web
service.  When I copy the web service over to production server, I get a:
System.IO module not found error.
DependencyWalker states I'm missing DWMAPI.dll, but from posts I see this is
a red herring.
Is there anyway to solve this without the manifest thing you talk about.
I'm clueless on how to resolve that?
Thanks......
Traian Stanev wrote:
> That is just bizarre. Shows you how much I understand that manifest thing
> though. Yes, that's probably the right fix.
> Traian
>> -----Original Message-----
>> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-
>> bounces at lists.osgeo.org] On Behalf Of Jackie Ng
>> Sent: Tuesday, February 05, 2008 2:00 PM
>> To: fdo-users at lists.osgeo.org
>> Subject: RE: [fdo-users] OGR 3.3 Provider runtime error [SOLVED]
>> I solved the problem, but it was the other way round.
>> The release configuration for the OGRProvider vcproj *did not* have
>> manifest
>> generation and embedding enabled. I turned these options on, rebuilt
>> the
>> project and now I no longer get the runtime errors.
>> I don't work with VC++ that much, so I dunno if this qualifies as an
>> actual
>> "fix", but there you have it.
>> - Jackie
>> > The depends dump looks good, however I just thought of what may be
>> causing
>> > this. Some time ago Kenneth posted about a similar problem. I
>> remember him
>> > mentioning that it was due to a manifest being embedded in the
>> OGRProvider
>> > dll at build time. Removing the embedded manifest fixed the problem
>> for
>> > him. We need to check the OGRProvider vcproj file for that problem
>> and fix
>> > it if the manifest is turned on.
>> > Traian
>> > [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Traian Stanev
>> > Sent: Thursday, January 24, 2008 11:07 PM
>> > Depends can export the dependency graph to a file. If you could
>> export
>> > yours and send it over I can take a quick look. Since the file can be
>> > large, email it to me only.
>> > Traian
>> > [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
>> > Sent: Thursday, January 24, 2008 11:04 PM
>> > That is correct, there are no red C++ functions listed.
>> > - Jackie
>> >> So, you open depends for OGRProvider.dll, pick FDO.dll from the
>> tree-view
>> >> on the top left, and then look on the right side. It will show
>> functions
>> >> from FDO.dll that the OGRProvider calls. Most of them will have a
>> green
>> >> "C++" next to them. Are you saying none of them have a red C++ if
>> you do
>> >> this?
>> >> Traian
>> >>> Sent: Tuesday, January 22, 2008 3:03 AM
>> >>> I've combed through the list of functions (OGRProvider.dll and
>> directly
>> >>> related dlls) and couldn't find any red ones. However the log
>> window
>> >>> did say
>> >>> there was at least one unresolved export function in one of the
>> delay-
>> >>> load
>> >>> dependent modules, but it doesn't say which one??
>> >>> - Jackie
>> >>> > DWMAPI.dll is a common false positive that depends throws. That's
>> not
>> >>> your
>> >>> > actual problem.
>> >>> > In depends, look in one of the right panes (the one in the
>> middle,
>> >>> not the
>> >>> > top right), where it lists all the dependent DLL functions that
>> are
>> >>> needed
>> >>> > by the provider. See if any of them are listed in red.
>> >>> > Traian
>> >>> > ________________________________________
>> >>> > [fdo-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
>> >>> > [jackie.ng at aecsystems.com.au]
>> >>> > Sent: Monday, January 21, 2008 11:49 PM
>> >>> > Subject: [fdo-users] OGR 3.3 Provider runtime error
>> >>> > Hi List,
>> >>> > I have an application that interrogates a provider's connection
>> >>> > properties,
>> >>> > but when I want to get the connection properties of the OGR
>> provider.
>> >>> I
>> >>> > get
>> >>> > the following error:
>> >>> > Microsoft Visual C++ Runtime Library
>> >>> > Runtime Error!
>> >>> > Program: [path to executable]
>> >>> > R6034
>> >>> > An Application has made an attempt to load the C runtime library
>> >>> > incorrectly.
>> >>> > Please contact the application's support team for more
>> information.
>> >>> > If I run this through the vs debugger, I get an unhandled
>> >>> > OSGeo.FDO.Common.Exception with the following message.
>> >>> > "Unable to load the FDO Provider: A dynamic link library (DLL)
>> >>> > initialization routine failed."
>> >>> > Running OGRProvider.dll through depends.exe, I found that it was
>> has
>> >>> a
>> >>> > missing dependency dwmapi.dll, which after some googling turns
>> out to
>> >>> be a
>> >>> > Windows Vista dll (???). So I downloaded the file anyway, and put
>> it
>> >>> into
>> >>> > the working directory, but I still get the same error messages.
>> >>> > I am using FDO 3.3.0 RC1 (binaries, not built from source) on
>> Windows
>> >>> XP.
>> >>> > I am using the managed dlls.
>> >>> > Any ideas?
>> >>> > - Jackie
>> >>> > View this message in context:
>> >>> > http://www.nabble.com/OGR-3.3-Provider-runtime-error-
>> >>> tp15012644s18162p15012644.html
>> >>> > Sent from the fdo-users mailing list archive at Nabble.com.
>> >>> > _______________________________________________
>> >>> > http://lists.osgeo.org/mailman/listinfo/fdo-users
>> >>> View this message in context: http://www.nabble.com/OGR-3.3-
>> Provider-
>> >>> runtime-error-tp15012644s18162p15014222.html
>> tp15012644s18162p15080594.html
>> View this message in context: http://www.nabble.com/OGR-3.3-Provider-
>> runtime-error-tp15012644s18162p15296982.html
View this message in context: http://n2.nabble.com/OGR-3.3-Provider-runtime-error-tp2049256p2342044.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
