[fdo-users] inserting data into a SDF file
Jackie Ng jumpinjackie at gmail.com
Thu Feb 19 19:31:37 EST 2009
If you look at the property value collection of the insert command in the
debugger, you will see the count will increase in increments of 4.
As a result, the insert command will use the same first 4 property values
for every insert operation.
To fix this, clear the property value collection of the insert command
before setting the property values.
Hope that helps.
- Jackie
vinay wrote:
> Hi All,
> I am using the FDO dlls from the MAP ObjectArx SDK 2009  in Visual studio
> 2008. I am writing a small app to understand FDO API. I am able to create
> a sdf file, describe schema for the sdf file, create feature class, etc. I
> created four datapropertydefinitions in which one is an identityProperty.
> I am inserting values into my properties in a for-loop. When I open this
> sdf file in map 2009, all columns have the same values except the auto
> generated property column as shown below.
> Please take a look in case I am missing something simple here.
>  http://n2.nabble.com/file/n2349739/data.png
> Source code snippets for the sample app is below
> OSGeo.FDO.Schema.FeatureSchema Schema = new
> OSGeo.FDO.Schema.FeatureSchema("SchemaOne", "Sample Schema");
>                         OSGeo.FDO.Schema.FeatureClass ClassOne = new
> OSGeo.FDO.Schema.FeatureClass("Class one", "Class one for Schema One");
>                         OSGeo.FDO.Schema.DataPropertyDefinition DataProp1
> = new OSGeo.FDO.Schema.DataPropertyDefinition("Prop1", "Property one");
>                         OSGeo.FDO.Schema.DataPropertyDefinition DataProp2
> = new OSGeo.FDO.Schema.DataPropertyDefinition("Prop2", "Property two");
>                         OSGeo.FDO.Schema.DataPropertyDefinition DataProp3
> = new OSGeo.FDO.Schema.DataPropertyDefinition("Prop3", "Property three");
>                         OSGeo.FDO.Schema.DataPropertyDefinition DataProp4
> = new OSGeo.FDO.Schema.DataPropertyDefinition("Prop4", "Property four");
>                         DataProp1.DataType =
> OSGeo.FDO.Schema.DataType.DataType_Int32;
>                         DataProp1.IsAutoGenerated = true;
>                         DataProp1.Nullable = false;
>                         DataProp2.DataType =
> OSGeo.FDO.Schema.DataType.DataType_Decimal;
>                         DataProp2.IsAutoGenerated = false;
>                         DataProp2.Nullable = false;
>                         DataProp2.ReadOnly = false;
>                         DataProp3.DataType =
>                         DataProp3.IsAutoGenerated = false;
>                         DataProp3.Nullable = false;
>                         DataProp3.ReadOnly = false;
>                         DataProp4.DataType =
> OSGeo.FDO.Schema.DataType.DataType_String;
>                         DataProp4.IsAutoGenerated = false;
>                         DataProp4.Nullable = false;
>                         DataProp4.ReadOnly = false;
>                         DataProp4.Length = 20;
>                         //Class one data props
>                         ClassOne.Properties.Add(DataProp1);
>                         ClassOne.IdentityProperties.Add(DataProp1);
>                         ClassOne.Properties.Add(DataProp2);
>                         ClassOne.Properties.Add(DataProp3);
>                         ClassOne.Properties.Add(DataProp4);
> OSGeo.FDO.Connections.Capabilities.IConnectionCapabilities connCap =
> conn.ConnectionCapabilities;
>                         ITransaction fdoTrans = null;
>                         if (connCap.SupportsTransactions())
>                             fdoTrans = conn.BeginTransaction();
>                         using (OSGeo.FDO.Commands.Feature.IInsert insert =
> conn.CreateCommand(OSGeo.FDO.Commands.CommandType.CommandType_Insert) as
> OSGeo.FDO.Commands.Feature.IInsert)
>                             for (int nIndex = 1; nIndex < 5; nIndex++)
>                                 OSGeo.FDO.Commands.PropertyValue
> PropValue1 = null;
>                                 PropValue1 = new
> OSGeo.FDO.Commands.PropertyValue();
>                                 PropValue1.SetName(DataProp1.Name);
>                                 PropValue1.Value = new
> OSGeo.FDO.Expression.Int32Value(nIndex);
>                                 insert.PropertyValues.Add(PropValue1);
>                                 PropValue1 = null;
>                                 PropValue1 = new
>                                 PropValue1.SetName(DataProp2.Name);
> OSGeo.FDO.Expression.DecimalValue(1000.50 + nIndex);
>                                 PropValue1 = null;
>                                 PropValue1 = new
>                                 PropValue1.SetName(DataProp3.Name);
> OSGeo.FDO.Expression.DecimalValue(2000.50 + nIndex);
>                                 PropValue1 = null;
>                                 PropValue1 = new
>                                 PropValue1.SetName(DataProp4.Name);
> OSGeo.FDO.Expression.StringValue("Note"+nIndex.ToString());
>                                 try
>                                     using
> (OSGeo.FDO.Commands.Feature.IFeatureReader reader = insert.Execute())
>                                         while (reader.ReadNext()) { }
>                                 catch (Exception ex)
>                                     //throw new
> FeatureServiceException("Error inserting new feature", ex);
>                                     MessageBox.Show(ex.Message);
>                             fdoTrans.Commit();
>                         conn.Close();
View this message in context: http://n2.nabble.com/inserting-data-into-a-SDF-file-tp2349739p2356377.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
