[fdo-users] Provider Properties Details Wish
Dan Stoica dan.stoica at autodesk.com
Thu Feb 26 11:07:31 EST 2009
The info you need is available through the connection object:
       FdoPtr<FdoIConnectionInfo> connInfo = mConnection->GetConnectionInfo();
Where FdoIConnectionInfo has this method:
    /// \brief
    /// Returns the provider type. A provider can be a file-based, database-based or
    /// web-based provider. The valid values the function may return are defined in
    /// the enumeration FdoProviderDatastoreType. The enumeration includes the following
    /// values: FdoProviderDatastoreType_Unknown, FdoProviderDatastoreType_File,
    /// FdoProviderDatastoreType_DatabaseServer, FdoProviderDatastoreType_WebServer.
    /// \return
    /// Returns the provider data store type.
    FDO_API virtual FdoProviderDatastoreType GetProviderDatastoreType() = 0;
Then with this you can dig further for detailed info:
FdoPtr<FdoIConnectionPropertyDictionary> connProps = connInfo->GetConnectionProperties();
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Crispin_at_1Spatial
Sent: Thursday, February 26, 2009 10:37 AM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] Provider Properties Details Wish
The FDO provider classes have methods that enable the auto generation of the
user interfaces that create a FDO connection. However there is some
information the providers should provide but don’t / could.
For instance, it is not possible to find out if a string parameter
represents a file name, or a password. So the auto generated user interface
code cannot instantiate the file open panel, or anonymize a password field.
I assume this seemingly simple change would require a fairly major RFC and
support by all the providers.
If there are alternative workarounds to this I would be glad to hear...
View this message in context: http://n2.nabble.com/Provider-Properties-Details-Wish-tp2390311p2390311.html
Sent from the FDO Users mailing list archive at Nabble.com.
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users mailing list
