[fdo-users] King Oracle - 64 bit client???
Martin Morrison martin.morrison at edsi.com
Fri Jan 30 15:49:24 EST 2009
Haris,
Did you get Oracle on Vista 64 working?
Thanks,
Martin
From: Haris Kurtagic (via Nabble) [mailto:ml-user+67233-213466401 at n2.nabble.com]
Sent: Tuesday, January 06, 2009 4:03 PM
To: Martin Morrison
Subject: RE: [fdo-users] King Oracle - 64 bit client???
Surprises me that you get ora-12154 for that connection string.
I will switch tomorrow for first time to Vista 64.
I have issues to solve with latest King.Oracle too and I plan to put
some time in it. I think sometime in January would be most accurate
timing
Haris
-----Original Message-----
From: fdo-users-bounces at ...<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2119383&i=0>
[mailto:fdo-users-bounces at ...<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2119383&i=1>] On Behalf Of Martin Morrison
Sent: Tuesday, January 06, 2009 9:43 PM
To: fdo-users at ...<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2119383&i=2>
Within AutoCAD at the "Connect to Data" window, the service is
"//localhost/xe", the OracleSchema is "XE", of course the user and pass
are
filled in.
Thanks,
Martin
Haris Kurtagic wrote:
> What your connection string looks like ?
> Haris
> From: fdo-users-bounces at ...<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2119383&i=3>
> [mailto:fdo-users-bounces at ...<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2119383&i=4>] On Behalf Of Martin
Morrison
> Sent: Tuesday, January 06, 2009 9:15 PM
> To: fdo-users at ...<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2119383&i=5>
> Subject: [fdo-users] King Oracle - 64 bit client???
> Hi,
> I have a Vista 64 workstation with Oracle XE running locally.  I have
> managed to connect via SQLPlus and to load data using FDO2FDO.  I am
> trying
> to connect to the data from within Civil 3D 2009 using the Map
> functionality
> (32 bit) .  I've downloaded the 32 bit SL-King driver but can not get
> the
> connection work.  ora-12154  This would seem to be a tnsnames issue
but
> I
> can connect via other methods.  Any suggestions?
> Will there be a 64 bit SL-King driver released soon?
> Thanks,
> Martin
http://n2.nabble.com/King-Oracle---64-bit-client----tp2119167p2119167.ht
> ml
> Sent from the FDO Users mailing list archive at Nabble.com.
> fdo-users mailing list
> fdo-users at ...<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2119383&i=6>
> http://lists.osgeo.org/mailman/listinfo/fdo-users
> fdo-users at ...<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2119383&i=7>
http://n2.nabble.com/King-Oracle---64-bit-client----tp2119167p2119295.ht
ml
fdo-users at ...<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2119383&i=8>
fdo-users at ...<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2119383&i=9>
This email is a reply to your post @ http://n2.nabble.com/King-Oracle---64-bit-client----tp2119167p2119383.html
You can reply by email or by visting the link above.
View this message in context: http://n2.nabble.com/King-Oracle---64-bit-client----tp2119167p2247002.html
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20090130/846152d1/attachment.html
More information about the fdo-users mailing list
