[fdo-users] PostGIS and Map 3D 2010 autoincrement problems
Astrid Emde astrid.emde at wheregroup.com
Thu Jul 16 09:30:39 EDT 2009
Hello list,
I have the same problem like Mike and Dave.
My wish would be to use AutoCAD Map 3D without the use of TRIGGER which
controls my gid.
Is there a discussion about this in the FDO team or the AutoCAD team
already going on?
David:
It would be nice if you could send me more information about your TRIGGER
solution.
best regards astrid
On Tue, June 23, 2009 11:37 pm, David Anderson wrote:
> Mike:
> I finally figured out a workaround.  In a nutshell:
> 	Create TRIGGER and FUNCTION to set NEW.gid to
> nextval('some_sequence'::regclass)
> 	TRIGGER should be on BEFORE INSERT event.
> 	Default value of the gid column should be set to 1 (it will be
> changed by the TRIGGER).
> If you would like more detailed steps, including the SQL statements, let
> me know.
> Map 3D adds the features appropriately by sending a 1 as the gid.  The
> data table will still show a 1 until the layer is refreshed.
> I don't know if this is an FDO issue or an AutoCAD issue.  Any comments
> from some more knowledgeable users would be appreciated.
> Thanks,
> David
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Mike Toews
> Sent: Monday, June 22, 2009 5:53 PM
> To: FDO Users Mail List
> Subject: Re: [fdo-users] PostGIS and Map 3D 2010 autoincrement problems
> David,
> Yikes. I've been demoing Map3D 2010 for the past few weeks to see if we
> want to upgrade from 2008, and I can reproduce the same behavior you
> describe in 2010. This behavior is new to me, since it is not an issue
> with 2008 (the serial appears as 0 in the table, as you described, until
> it is checked-in and refreshed).
> To add details, the error response from 2010 when trying to check-in a
> new feature:
> <Error code="200" type="5" dispensation="3" sId="2"
> occurrence="1">Feature was not saved in the target feature
> source.<Parameters>
> <Parameter classId="0" position="0">
> <Message>2=Invalid property value name 'gid'.
> </Message>
> <SQL></SQL>
> </Parameter>
> <Message>1=Failed to execute Fdo command.
> </Message>
> <SQL></SQL>
> </Parameter>
> <Message>Failed to insert feature.</Message>
> <SQL></SQL>
> </Parameter>
> <Message>FdoPostGIS:mytable (), Rev# &lt;0&gt;</Message>
> <SQL></SQL>
> </Parameter></Parameters>
> <Entry code="1" type="15" sId="3" occurrence="1">Failed to save some
> features.</Entry>
> <Entry code="1" type="15" sId="4" occurrence="1">Failed to save edit
> set.</Entry>
> </Error>
> In QGIS and other programs, the default value for a serial (integer)
> that is shown in the property before insert/commit is
> "nextval('mytable_gid_seq'::regclass)", which might explain the error
> message "Invalid property value name 'gid'", since it appears as a
> string, not an integer in this form.
> I tried fixing this with some trigger functions within the database, but
> whatever I've tried I can't seem to make a workaround. The best I can do
> is raise some exception in a before trigger, which shows up in the error
> message in AutoCAD, but making a trigger that sets "NEW.gid :=
> nextval('mytable_gid_seq'::regclass);" still throws the error shown
> above.
> Is this an issue with FDO or with AutoCAD Map3D 2010?
> -Mike
>> I have been trying to setup Map 3D 2010 to access a PostGIS database
>> that has a feature set to auto increment the primary key. When trying
>> to create a new feature, Map 3D complains about the gid being invalid
>> because it tries to add it as 0. Map 3D won't let me change the value
>> because it is controlling it. If I check in the feature, close the
>> drawing, reopen the drawing Map 3D shows the feature even though it
>> was saying it couldn't be added. I have tried with various
>> combinations of PostgreSQL 8.2 & 8.3 and PostGIS 1.3.4-1.3.6 with the
>> same results.
>> Is anybody successfully using Map 3D with the auto increment setting?
>> Does this only work with a certain data type? Any help would be
>> greatly appreciated.
>> QGIS and uDig both access the database properly and can add features
>> so the database is working in that respect.
>> Thanks,
>> David
>> fdo-users mailing list
>> fdo-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/fdo-users
Mit freundlichen Grüßen
Astrid Emde
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
 Astrid Emde
 WhereGroup GmbH & Co.KG
 Siemensstraße 8
 53121 Bonn
 Germany
 Fon: +49(0)228 90 90 38 - 19
 Fax: +49(0)228 90 90 38 - 11
 www.wheregroup.com
 Amtsgericht Bonn, HRA 6788
 Komplementärin:
 WhereGroup Verwaltungs GmbH
 vertreten durch:
 Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the fdo-users mailing list
