[fdo-users] Having problem with FDO Postgis and OGR Provider
psergio psergio at mediaprimer.pt
Mon Jul 20 05:19:55 EDT 2009
Hello Bruno
I already found the solution.
The problem is that i was using Autodesk MapGuide Studio to set the
coordinate system to MapGuide OpenSource, and it seems that the Datum 73
Modified Portuguese grid is different from the one that PostGis is using,
The solution is setting this coordinate system with Mapguide Maestro Typing
the ESPG 27492 and it works perfectly.
Open source has saved me again :)...
Many thanks for your reply.
Best regards.
Paulo
View this message in context: http://n2.nabble.com/Having-problem-with-FDO-Postgis-and-OGR-Provider-tp3255100p3287842.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
