[fdo-users] AutoCAD Map 3D 2010 FDO PostGIS 3.4 Filtering with position does not work
Hermann Karl Karl.Hermann at dornbirn.at
Mon Jul 27 11:15:54 EDT 2009
Hello List,
If i try to filter the FDO Layer in a map by a point position or when i
tried to filter features when i
add them to a map by a rectangle then i get the following
message
FDO-command could not be executed
geometry typ is not supported
The execution fo Select command failed
16:41:13:516 (0x00000DE8) :  Configuring filter
16:41:13:516 (0x00000DE8) :  >>[FilterProcessor::FilterProcessor]
16:41:13:516 (0x00000DE8) :   SRID = 26986
16:41:13:516 (0x00000DE8) :  <<[FilterProcessor::FilterProcessor]
>>[FilterProcessor::+ProcessSpatialCondition]
16:41:13:516 (0x00000DE8) :   Spatial operation id: 4
>>[ExpressionProcessor::+ProcessIdentifier]
16:41:13:516 (0x00000DE8) :    Identifier name: the_geom
16:41:13:516 (0x00000DE8) :    Expression text: the_geom
<<[ExpressionProcessor::+ProcessIdentifier]
>>[ExpressionProcessor::ProcessGeometryValue]
16:41:13:516 (0x00000DE8) :    Geometry: MULTIPOINT XYZ
(150116.213498857 908266.345680585 0)
<<[ExpressionProcessor::ProcessGeometryValue]
<<[FilterProcessor::+ProcessSpatialCondition]
16:41:13:516 (0x00000DE8) :  ERROR: The execution of Select command
failed.
16:41:13:516 (0x00000DE8) : <<[SelectCommand::+Execute]
the geometrytype of the table towns is "GEOMETRY" and table is without
oids
any idea what is wrong
Karl Hermann
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20090727/b58fd89c/attachment.html
More information about the fdo-users mailing list
