[fdo-users] RE: ESRI File Geodatabases
Steve Hinchee shinchee at wheatonparks.org
Thu Mar 12 12:37:09 EDT 2009
Brad
I'm by no means an expert on this subject, but I have been reading this string for the past week or two. There is a difference between an ESRI File Geodatabase and an ESRI Personal Geodatabase. I believe the File Geodatabase was a new feature with their 9.3 software and I'm not sure what format it is in. The Personal Geodatabase is in MBD format and I believe OGR only supports the Personal Geodatabase right now.
Like I said, I'm not an expert on this, but that is my understanding of things. Perhaps someone who knows more can shed more light on it than me, but I didn't want to see you keep beating your head against a brick wall.
If you need to use the information in both ESRI and AutoCAD I'd recommend converting your File Geodatabases to Personal Geodatabase. It's fairly easy to do. That is how I'm doing things for right now.
Steve
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of fdo-users-request at lists.osgeo.org
Sent: Thursday, March 12, 2009 11:00 AM
To: fdo-users at lists.osgeo.org
Subject: fdo-users Digest, Vol 27, Issue 14
Send fdo-users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
	http://lists.osgeo.org/mailman/listinfo/fdo-users
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
	fdo-users-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific
than "Re: Contents of fdo-users digest..."
Today's Topics:
   1. RE: RE: ESRI File Geodatabases (Brad Nesom)
Message: 1
Date: Thu, 12 Mar 2009 08:56:53 -0500
Subject: RE: [fdo-users] RE: ESRI File Geodatabases
To: FDO Users Mail List <fdo-users at lists.osgeo.org>
Message-ID: <BLU130-W3503D83C57542497B08754E49F0 at phx.gbl>
Content-Type: text/plain; charset="windows-1252"
Not sure what I am doing wrong.
 I have the provider dll you sent in the fdo bin directory. I get a successfull connection but when I add it to the map it says
failed to cache features
geometry is null.
 I have tried this with several pgdb's that I have verified do work in esri software.
Brad
> From: traian.stanev at autodesk.com
> Date: Tue, 10 Mar 2009 07:21:55 -0700
> I already posted it but forgot to send an email.
> http://13-9.com/OGRProvider-3.3-nopq.zip
> Write support does not depend on the provider, but on the underlying OGR driver, so I am the wrong person to ask about that.
> Traian
> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Brad Nesom
> Sent: Tuesday, March 10, 2009 10:12 AM
> To: 'FDO Users Mail List'
> Thanks Traian,
> If you don't mind I would like the newly compiled dll.
> Brad
> Is there any plan to make a read/write version?
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Traian Stanev
> Sent: Monday, March 09, 2009 9:28 AM
> The provider dll I posted is compiled with postgis support, which requires
> an external dll from Postgres (libpq.dll), which is likely what you are
> missing. I could probably recompile without that and post a new one, later
> today. (Or you could get the libpq.dll and its dependencies from a Postgres
> package).
> The provider I posted is compiled with ODBC support as well, which is what
> you are missing from the one that comes with the FDO package. It's really
> the default build of the GDAL dll that has that missing, and the one I
> posted is statically linked to a build of GDAL with ODBC enabled. I have
> tried it with geodatabases in the past, in Map3D, and it definitely works,
> once you can load the provider. :)
> Traian
> Sent: Monday, March 09, 2009 10:19 AM
> Traian,
> I have since my last post downloaded the dll provided in your last post. I
> removed the 3.3.2 fdo and re-loaded the 3.3.0 from the original autodesk
> install. At that point I noticed there was no ogr provider in the original.
> So I added the following to my providers.xml
> <FeatureProvider>
> <Name>OSGeo.OGR.3.3</Name>
> <DisplayName>OSGeo FDO Provider for OGR </DisplayName>
> <Description>Read access to OGC OGR-based data store. </Description>
> <IsManaged>False</IsManaged>
> <Version>3.3.0.0</Version>
> <FeatureDataObjectsVersion>3.3.0.0</FeatureDataObjectsVersion>
> <LibraryPath>OGRProvider.dll</LibraryPath>
> </FeatureProvider>
> And place the ogrprovider.dll in my fdo/bin folder. When I start map I get
> the error stack following...
> <?xml version="1.0" ?>
> - <Map3dErrorLog xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:noNamespaceSchemaLocation="AcMap3dErrorLog.xsd">
> - <Session user="ws21" start="3/9/2009 9:18:51 AM" document="Drawing1.dwg">
> - <Error code="1" type="15" dispensation="1" sId="2" occurrence="1">
> Failed to load connection control for provider. Either the provider is not
> installed or there was an error accessing it.
> <Entry code="1" type="15" sId="3" occurrence="1">Unable to create
> connection to provider 'OSGeo.OGR.3.3'</Entry>
> <Entry code="1" type="15" sId="4" occurrence="1">Unable to load the FDO
> Provider: The specified module could not be found.</Entry>
> <Entry code="1" type="15" sId="5" occurrence="1">Failed to load connection
> control for provider. Either the provider is not installed or there was an
> error accessing it.</Entry>
> <Entry code="1" type="15" sId="6" occurrence="1">Unable to create
> <Entry code="1" type="15" sId="7" occurrence="1">Unable to load the FDO
> </Error>
> </Session>
> </Map3dErrorLog>
> Sent: Monday, March 09, 2009 7:30 AM
> No, the 3.3.0 version I am using is the shipped with and installed with
> autodesk map 3d 2009.
> At this time I have the 3.3.2 version installe from the fdo downloads...
> http://fdo.osgeo.org/content/fdo-332-downloads
> Windows SDK
> The following tar files contains the Windows (32 bit) Managed and Unmanaged
> FDO SDK files, including binaries, libraries and header files.
> fdosdk-win32-3.3.2.tar.gz
> Sent: Friday, March 06, 2009 5:55 PM
> Which OGRProvider.dll are you using -- the one I posted at the URL below?
> http://13-9.com/OGRProvider-3.3.0.zip
> Traian
> ________________________________________
> From: fdo-users-bounces at lists.osgeo.org [fdo-users-bounces at lists.osgeo.org]
> On Behalf Of Brad Nesom [kidsmake6 at msn.com]
> Sent: Friday, March 06, 2009 5:51 PM
> Traian,
> I am unable to accomplish even read only of the MDB in 3.3.0 or 3.3.2.
> Also the documentation shows that is it read/write.
> http://fdo.osgeo.org/OSProviderOverviews.html
> OSGeo FDO Provider for OGR<http://fdo.osgeo.org/fdoogr/index.html>
> OGR is a open source library. Read and write access is provided to vector
> data from the OGR library
> Sent: Friday, March 06, 2009 9:10 AM
> Subject: [fdo-users] RE: ESRI File Geodatabases
> Hi David,
> If you are talking about the personal geodatabase, that's in MDB format -
> you can read those with the OGR provider, in both 3.3 and 3.4. Note that
> support is read only.
> Traian
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of David Anderson
> Sent: Thursday, March 05, 2009 3:14 PM
> Subject: [fdo-users] ESRI File Geodatabases
> Does 3.3 or 3.4 support the ESRI file geodatabase?
> Thanks,
> David Anderson, P.E.
> Donnell & Allred, Inc.
> 908 Big Horn Ave
> P.O. Box 638
> Worland, WY 82401
> 307-347-8276
> 307-347-8277 fax
> da at donnellandallred.com<mailto:da at donnellandallred.com>
_________________________________________________________________
Windows Live? Groups: Create an online spot for your favorite groups to meet.
http://windowslive.com/online/groups?ocid=TXT_TAGLM_WL_groups_032009
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20090312/a2a20b6f/attachment-0001.html
End of fdo-users Digest, Vol 27, Issue 14
More information about the fdo-users mailing list
