[fdo-users] ESRI File Geodatabases
Crispin_at_1Spatial crispin.hoult at 1spatial.com
Fri Mar 13 09:00:31 EDT 2009
OK,
I have tried this DLL in AutoCAD Map 2009 SP1 and also in our alternative
MapRelate solution.
Success on both camps - especially pleased with this build including xerces
support means that I can read GML into AutoCAD now!  Thanks Trian.
The sample GeoDatabase I am using came from the interweb somewhere and to
utilise the personal geodatabase I first created a System-ODBC connection to
the MDB file in the Windows ODBC administrator - in my case I called my
sample ODBC connection 'pgeo_somerset'.
Then in Map I did a 'Add OGR Connection' and in the box for datasource put
this exact format (from the OGR documentation) - ie the "PGeo:" prefix and
then the ODBC connection name:
    PGeo:pgeo_somerset
I hope this helps.
 Crispin
View this message in context: http://n2.nabble.com/ESRI-File-Geodatabases-tp2431900p2473261.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
