[fdo-users] Insert new feature object on SHP File
Matteo matteo.conte1979 at libero.it
Sun Nov 1 16:39:04 EST 2009
Thanks a lot Jason. Now work fine.
Regards,
Matteo
Jason Birch wrote:
> I'm not an FDO coder, but there are a couple things I'd look at.
> First, FDODimensionality isn't an integer value representing the number of
> dimensions, it's a bit-field enumeration. In this case, 2 evaluates to
> FdoDimensionality_M (although, since the value of FdoDimensionality_XY is
> 0,
> this is included by default in the evaluation of FdoDimensionality_M -
> neat).
> http://fdo.osgeo.org/files/fdo/docs/FDO_API/d3/d95/group__enums_g3778ef9845e2ba00e8669c32ec42e113.htm#g3778ef9845e2ba00e8669c32ec42e113
> Second, the docs for CreateLineString indicate that it's looking for the
> number of ordinates, not co-ordinates.  I'm not sure if this is just a
> terminology issue, but perhaps it is looking for 6 in your case.
> http://fdo.osgeo.org/files/fdo/docs/FDO_API/d1/d7d/class_fdo_fgf_geometry_factory_0e122ad008ada729f974e407aa1285dd.htm#0e122ad008ada729f974e407aa1285dd
> Jason
> 2009/11/1 Matteo <matteo.conte1979 at libero.it>
>> Hi all,
>>  I'm new on FDO. I try to insert a new feature object on a shp file with
>> VB.NET but i get this error "The type of geometry ( 'PolyLineM')
>> geographical entity creates a conflict with the type of shape file (
>> 'Polyline')."
>> This is the code:
>> Dim objCmdI As Commands.Feature.IInsert =
>> objConn.CreateCommand(Commands.CommandType.CommandType_Insert)
>>        objCmdI.SetFeatureClassName(objClass.Name)
>>        Dim objPropsValues As Commands.PropertyValueCollection =
>> objCmdI.PropertyValues()
>>        Dim objPropV As Commands.PropertyValue = New
>> Commands.PropertyValue()
>>        objPropV.SetName("ID")
>>        objPropV.Value = New OSGeo.FDO.Expression.Int32Value(2)
>>        objPropsValues.Add(objPropV)
>>        objPropV = New Commands.PropertyValue()
>>        objPropV.SetName("Geometry")
>>        Dim objGeomV As Geometry.FgfGeometryFactory = New
>> Geometry.FgfGeometryFactory()
>>        Dim objCoords(5) As Double
>>        objCoords(0) = 0
>>        objCoords(1) = 0
>>        objCoords(2) = 10
>>        objCoords(3) = 10
>>        objCoords(4) = 50
>>        objCoords(5) = 20
>>        Dim objLine As Geometry.ILineString = objGeomV.CreateLineString(2,
>> 3, objCoords)
>> OSGeo.FDO.Expression.GeometryValue(objGeomV.GetFgf(objLine))
>>        objCmdI.Execute()
>>        objConn.Flush()
>> Can you help me?
>> Regards,
>> Matteo
>> View this message in context:
>> http://n2.nabble.com/Insert-new-feature-object-on-SHP-File-tp3928348p3928348.html
>> Sent from the FDO Users mailing list archive at Nabble.com.
>> fdo-users mailing list
>> fdo-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/fdo-users
View this message in context: http://n2.nabble.com/Insert-new-feature-object-on-SHP-File-tp3928348p3928709.html
More information about the fdo-users mailing list
