[fdo-users] FDO 3.5 RC1 crashes MGOS v2.1
miansi AndreiSinelnikov at SierraSystems.com
Tue Apr 13 16:50:20 EDT 2010
Hello,
Just tested FDO 3.5 RC1 on MGOS v2.1.
Currently I am using FDO, which comes with MGOS v2.1 install and patched FDO
for SQL Server from Autodesk to resolve feature selection problem in SQL
2008. I raised that defect long time ago but seems that it wasn't resolved
in FDO v3.4, so I wanted to see if that was resolved in FDO v3.5.
1. I stopped MGOS service
2. I replaced all files in:
c:\Program Files (x86)\OSGeo\MapGuide\Server\Fdo
with files from FDO download section (32 bit)
3. Start MGOS Service
4. Restarted IIS
My test server is Windows Server 2008 R2 Standard x64.
I was able to connect to the server using Maestro. But as soon as I tried to
see Dataconnection properties or create new Dataconnection MGOS Service
stops and I saw an error:
http://n2.nabble.com/file/n4898413/FDO_v3.5.png
I also tried x64 version of FDO v3.5, but I wasnt able to start MGOS Service
at all with it.
Then I downloaded FDO v3.5 SDK and copied all files from bin directory.
After that I was able to see some errors in Error.log
In the error log file I see lots of references to c:\osgeo\mapguide_21\mgdev
location. Is that a problem? As my MGOS installation located in different
directory
Logs:
<2010-04-13T12:36:15> 	2716
 Success: Server started.
<2010-04-13T12:38:46> 	2716
 Success: Server stopped.
<2010-04-13T12:38:58> 	4324
<2010-04-13T12:39:45> 	4324
<2010-04-13T12:42:06> 	4520
<2010-04-13T12:42:54> 	4520
<2010-04-13T12:45:14> 	4456
<2010-04-13T12:48:11> 	1132
<2010-04-13T12:49:55> 	4896
<2010-04-13T12:50:08> 	3196	MapGuide Maestro v2.0.0.4650	::1
 Error: Session has expired or is invalid. Please log in again.
 StackTrace:
  - MgSiteServiceHandler.ProcessOperation() line 83 file
c:\osgeo\mapguide_21\mgdev\server\src\services\site\SiteServiceHandler.cpp
  - MgOpAuthenticate.Execute() line 107 file
c:\osgeo\mapguide_21\mgdev\server\src\services\site\OpAuthenticate.cpp
  - MgServerSiteService.Authenticate() line 709 file
c:\osgeo\mapguide_21\mgdev\server\src\services\site\ServerSiteService.cpp
  - MgSecurityManager.Authenticate() line 224 file
c:\osgeo\mapguide_21\mgdev\server\src\common\manager\SecurityManager.cpp
  - MgSessionCache.GetSessionInfo() line 175 file
c:\osgeo\mapguide_21\mgdev\server\src\common\manager\SessionCache.cpp
<2010-04-13T12:50:10> 	2164	MapGuide Maestro API v2.0.0.4650	::1
Administrator
 Error: Resource was not found:
Session:123147be-295b-102d-8000-005056ad042e_en_0A22201F0AFC0AFB0AFA//79334259-237b-41a2-9b3b-039984aa779b.FeatureSource
 StackTrace:
  - MgResourceServiceHandler.ProcessOperation() line 80 file
c:\osgeo\mapguide_21\mgdev\server\src\services\resource\ResourceServiceHandler.cpp
  - MgOpGetResourceContent.Execute() line 120 file
c:\osgeo\mapguide_21\mgdev\server\src\services\resource\OpGetResourceContent.cpp
  - MgServerResourceService.GetResourceContent() line 904 file
c:\osgeo\mapguide_21\mgdev\server\src\services\resource\ServerResourceService.cpp
  - MgApplicationRepositoryManager.GetResourceContent() line 383 file
c:\osgeo\mapguide_21\mgdev\server\src\services\resource\ApplicationRepositoryManager.cpp
  - MgResourceDefinitionManager.GetResource
(MgSessionResourceContents.dbxml)() line 320 file
c:\osgeo\mapguide_21\mgdev\server\src\services\resource\ResourceDefinitionManager.cpp
  - MgResourceContentManager.GetDocument() line 590 file
c:\osgeo\mapguide_21\mgdev\server\src\services\resource\ResourceContentManager.cpp
  - MgResourceDefinitionManager.GetDocument
(MgSessionResourceContents.dbxml)() line 476 file
  - MgResourceDefinitionManager.GetDocument() line 467 file
<2010-04-13T12:52:15> 	4896
<2010-04-13T12:59:33> 	4548
<2010-04-13T13:01:17> 	4640	MapGuide Maestro v2.0.0.4650	10.34.36.97
Administrator
 Error: An exception occurred in FDO component.
        Unable to load the FDO Provider: The specified procedure could not
be found.
 StackTrace:
  - MgFeatureServiceHandler.ProcessOperation() line 83 file
c:\osgeo\mapguide_21\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
  - MgOpTestFeatureSourceConnection.Execute() line 100 file
c:\osgeo\mapguide_21\mgdev\server\src\services\feature\OpTestFeatureSourceConnection.cpp
  - MgFdoConnectionManager.Open() line 262 file
c:\osgeo\mapguide_21\mgdev\server\src\common\manager\FdoConnectionManager.cpp
<2010-04-13T13:01:41> 	4548
<2010-04-13T13:02:43> 	2668
        Failed to load FDO library.
 StackTrace:
  - MgServer.open() line 1083 file
c:\osgeo\mapguide_21\mgdev\server\src\core\Server.cpp
  - MgServer.svc() line 979 file
<2010-04-13T13:02:44> 	2668
<2010-04-13T13:04:00> 	4752
Did I miss something?
Thank you,
Andrei
View this message in context: http://n2.nabble.com/FDO-3-5-RC1-crashes-MGOS-v2-1-tp4898413p4898413.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
