[fdo-users] RE: Fgf to Wkb
Gavin Cramer gavin.cramer at autodesk.com
Mon Dec 20 15:37:10 EST 2010
That does not sound right at all.  While using the FdoGeometry types won't be quite as fast as a direct binary conversion, I do not know of a reason for it to have anywhere near the performance problems that you report.
It sounds like there could be up to two problems:  fetching the geometry in FGF and converting the geometry to WKB.  The first one should be a direct binary conversion and even that is having a problem in this case.
If it is possible to share any of the data involved, I recommend filing an FDO defect so that it can be formally analysed and addressed.
Gavin
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of maland
Sent: Monday, December 20, 2010 3:33 PM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] RE: Fgf to Wkb
WKB byte array can be used to render the geometry.
We are a bit concerned about the performance of the FDO. For the specific
geometry referred to in this post, even this call to GetGeometry need 3-4
seconds to complete:
byte[] fgfBytes = reader.GetGeometry(p.Name);
We are using the OSGeo.ArcSDE provider.
Henning
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Fgf-to-Wkb-tp5850828p5853660.html
Sent from the FDO Users mailing list archive at Nabble.com.
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users mailing list
