[fdo-users] SDF2 to SDF3
Jackie Ng jumpinjackie at gmail.com
Mon Jan 18 07:23:01 EST 2010
FGF is the FDO Geometry Format. It is an extension of WKB (well known binary)
geometry format. You can find the differences here:
http://fdo.osgeo.org/files/fdo/docs/FDG_FDODevGuide/files/WSfacf1429558a55de8821c21057fbebc2b-78a.htm
SDF3 uses FGF as the native geometry format. The FDO API itself operates on
FGF geometries.
- Jackie
Davidow wrote:
> Hi Jackie
> What is FGF?
> Jackie Ng wrote:
>> The only known way to convert from SDF 2 to SDF 3 is to use the MapGuide
>> Studio API which has this functionality.
>> Another (completely) unproven/untested way would be to read from your
>> SDF2 file using the SDF component toolkit, convert the SDF2 geometry to
>> FGF (that's the tricky part), and write the converted features to your
>> SDF3 file.
>> - Jackie
>> Davidow wrote:
>>> Hello to all
>>> I would like to convert SDF data
>>> SDF version 2 to SDF version 3
>>> You know what some ways to implement this in. NET environment ?
View this message in context: http://n2.nabble.com/SDF2-to-SDF3-tp4290710p4413342.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
