[fdo-users] More funcionallity in Data Table of Autocad Map
Romica Dascalescu Romica.Dascalescu at autodesk.com
Mon Mar 8 08:42:15 EST 2010
You can use 'Search to Select' to find all records based on a condition then right click "Properties" (as Dan said) and you can set values to those selected properties.
Romy.
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Dan Stoica
Sent: Sunday, March 07, 2010 9:57 PM
To: FDO Users Mail List
Subject: RE: [fdo-users] More funcionallity in Data Table of Autocad Map
Given the description of the issue, I believe the "Properties" option (aka OPM) can accomplish this.
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Brad Nesom
Sent: Sunday, March 07, 2010 9:19 PM
Subject: Re: [fdo-users] More funcionallity in Data Table of Autocad Map
Sounds like you are referring to field calculator. No such thing in map that I know of.
On Sun, Mar 7, 2010 at 3:31 PM, brujulas <gis at cadmax.es<mailto:gis at cadmax.es>> wrote:
someone added more capabilities to AutoCAD Map to edit multiple records? I
want to make edits in various fields from several records at once, something
like that you may know what I mean, the tools we have in Arcgis of Select by
Attributes and Attributes
Thank you very much!
Greetings!
View this message in context: http://n2.nabble.com/More-funcionallity-in-Data-Table-of-Autocad-Map-tp4692055p4692055.html
Sent from the FDO Users mailing list archive at Nabble.com.
fdo-users mailing list
fdo-users at lists.osgeo.org<mailto:fdo-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/fdo-users
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20100308/396f6574/attachment.html
More information about the fdo-users mailing list
