[fdo-users] Re: More funcionallity in Data Table of Autocad Map
Martin Morrison martin.morrison at edsi.com
Mon Mar 8 12:18:17 EST 2010
What Dan was trying to say is:  If you select several objects in Map, then right click them, select properties, you can change the values of any of the fields for all of the objects at once.
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of brujulas
Sent: Monday, March 08, 2010 11:57 AM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] Re: More funcionallity in Data Table of Autocad Map
First of all, thank you very much for your answers
I need is a similar tool like Attributes in Arcgis (next image):
http://n2.nabble.com/file/n4696571/Dibujo.jpg
This tool allow a massive change in multiple records.
Any idea with FDO?
Greatings
View this message in context: http://n2.nabble.com/More-funcionallity-in-Data-Table-of-Autocad-Map-tp4692055p4696571.html
Sent from the FDO Users mailing list archive at Nabble.com.
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users mailing list
