[fdo-users] Re: More funcionallity in Data Table of Autocad Map
Brad Nesom kidsmake6 at msn.com
Mon Mar 8 12:55:09 EST 2010
brujulas
  As described by Dan and Romica, I was mistaken. The process would be to
1. Connect the data to map through FDO.
2. Use any number of methods to select the objects desired (pick on the
screen, select in the data view, select through the properties dialog).
3. Then in the properties dialog you can see the feature properties (which
in the case of shape file will be the attribtes of the feature/s). When more
than one objects are selected there will be "VARIES" in the value. Any
change to these values will apply to all selected features.
4. After changes are made you need to "check in" the features in the data
layer you have selected.
Brad
On Mon, Mar 8, 2010 at 10:56 AM, brujulas <gis at cadmax.es> wrote:
> Hi,
> First of all, thank you very much for your answers
> I need is a similar tool like Attributes in Arcgis (next image):
> http://n2.nabble.com/file/n4696571/Dibujo.jpg
> This tool allow a massive change in multiple records.
> Any idea with FDO?
> Greatings
> http://n2.nabble.com/More-funcionallity-in-Data-Table-of-Autocad-Map-tp4692055p4696571.html
>  Sent from the FDO Users mailing list archive at Nabble.com.
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20100308/74714523/attachment.html
More information about the fdo-users mailing list
