AW: [fdo-users] Autocad map 3D 2009, bulk copy
Hermann Karl Karl.Hermann at dornbirn.at
Tue May 4 04:19:39 EDT 2010
Hy Meryem,
look at this link may be it will help
http://lists.osgeo.org/pipermail/fdo-users/2009-September/001812.html
Karl
Von: fdo-users-bounces at lists.osgeo.org
[mailto:fdo-users-bounces at lists.osgeo.org] Im Auftrag von meryem el
boukhari
Gesendet: Montag, 03. Mai 2010 17:47
An: fdo-users at lists.osgeo.org
Betreff: [fdo-users] Autocad map 3D 2009, bulk copy
Hi every body, i am new user to this mailing list and i want someone to
help me please it's a little bit urgent
So i want to insert data from shapefile (ESRI) to my database in postgis
1.3.3, when using bulk copy with Autocad map 3D 2009 i get this message
"Attempted to read or write protected memory.This is often an indication
that other memory is corrupt".I granted all necesseray privileges to the
user but still the same problem.
Pls help me and thank you so much.
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20100504/a318ddc5/attachment.html
More information about the fdo-users mailing list
