AW: [fdo-users] Autocad map 3D 2009, bulk copy
Hermann Karl Karl.Hermann at dornbirn.at
Tue May 4 05:14:35 EDT 2010
Hi Meryem,
With the logged FdoPg33L vor AutoCAD Map 3d 2009 on
http://www.geomapgis.com/web/geomap-group/fdo/index.html
in the LogFile from PostgreSQL you can see whats going on
Karl
Von: fdo-users-bounces at lists.osgeo.org
[mailto:fdo-users-bounces at lists.osgeo.org] Im Auftrag von meryem el
boukhari
Gesendet: Dienstag, 04. Mai 2010 10:54
An: FDO Users Mail List
Betreff: Re: [fdo-users] Autocad map 3D 2009, bulk copy
Hi Karl,
I have tried what you have said but it doesn't work, i got the same
message. I really don't khow why i still have this problem.
I tried with privileges in the postgis database and it doesn't work
neither.
Pls can you help me, i don't khow what to do and i am very pressed
thx very much
2010/5/4 Hermann Karl <Karl.Hermann at dornbirn.at>
	Hy Meryem,
	look at this link may be it will help
http://lists.osgeo.org/pipermail/fdo-users/2009-September/001812.html
	Karl
boukhari
	Gesendet: Montag, 03. Mai 2010 17:47
	An: fdo-users at lists.osgeo.org
	Betreff: [fdo-users] Autocad map 3D 2009, bulk copy
	Hi every body, i am new user to this mailing list and i want
someone to help me please it's a little bit urgent
	So i want to insert data from shapefile (ESRI) to my database in
postgis 1.3.3, when using bulk copy with Autocad map 3D 2009 i get this
message
	"Attempted to read or write protected memory.This is often an
indication that other memory is corrupt".I granted all necesseray
privileges to the user but still the same problem.
	Pls help me and thank you so much.
	fdo-users mailing list
	http://lists.osgeo.org/mailman/listinfo/fdo-users
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20100504/1097449c/attachment-0001.html
More information about the fdo-users mailing list
