[fdo-users] Autocad map 3D 2009, bulk copy
meryem el boukhari meryem.elboukhari at gmail.com
Tue May 4 05:39:13 EDT 2010
Hi Karl,
Sorry for the disturbance, thank you for your answer.
In the logfile from postgresql i got this error: "new row for relation
"test" violates check constraint "enforce_geotype_geom_test""
If you have any idea thank you very much.
Meryem
2010/5/4 Hermann Karl <Karl.Hermann at dornbirn.at>
>  Hi Meryem,
> With the logged FdoPg33L vor AutoCAD Map 3d 2009 on
> http://www.geomapgis.com/web/geomap-group/fdo/index.html
> in the LogFile from PostgreSQL you can see whats going on
> Karl
> *Von:* fdo-users-bounces at lists.osgeo.org [mailto:
> fdo-users-bounces at lists.osgeo.org] *Im Auftrag von *meryem el boukhari
> *Gesendet:* Dienstag, 04. Mai 2010 10:54
> *An:* FDO Users Mail List
> *Betreff:* Re: [fdo-users] Autocad map 3D 2009, bulk copy
>  Hi Karl,
> I have tried what you have said but it doesn't work, i got the same
> message. I really don't khow why i still have this problem.
> I tried with privileges in the postgis database and it doesn't work
> neither.
> Pls can you help me, i don't khow what to do and i am very pressed
> thx very much
>>  Hy Meryem,
>> look at this link may be it will help
>> http://lists.osgeo.org/pipermail/fdo-users/2009-September/001812.html
>> Karl
>> *Gesendet:* Montag, 03. Mai 2010 17:47
>> *An:* fdo-users at lists.osgeo.org
>> *Betreff:* [fdo-users] Autocad map 3D 2009, bulk copy
>>   Hi every body, i am new user to this mailing list and i want someone to
>> help me please it's a little bit urgent
>> So i want to insert data from shapefile (ESRI) to my database in postgis
>> 1.3.3, when using bulk copy with Autocad map 3D 2009 i get this message
>> "Attempted to read or write protected memory.This is often an indication
>> that other memory is corrupt".I granted all necesseray privileges to the
>> user but still the same problem.
>> Pls help me and thank you so much.
>> fdo-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/fdo-users
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20100504/3da77493/attachment.html
More information about the fdo-users mailing list
