AW: [fdo-users] Autocad map 3D 2009, bulk copy
Hermann Karl Karl.Hermann at dornbirn.at
Tue May 4 06:12:51 EDT 2010
Hi Meryem,
look at this link
http://lists.osgeo.org/pipermail/fdo-users/2009-July/001736.html
compare AddGeometryColumn in Case 1 (MULTIPOLYGON) with
AddGeometryColumn Case 3 (GEOMETRY)
Karl
Von: fdo-users-bounces at lists.osgeo.org
[mailto:fdo-users-bounces at lists.osgeo.org] Im Auftrag von meryem el
boukhari
Gesendet: Dienstag, 04. Mai 2010 11:39
An: FDO Users Mail List
Betreff: Re: [fdo-users] Autocad map 3D 2009, bulk copy
Hi Karl,
Sorry for the disturbance, thank you for your answer.
In the logfile from postgresql i got this error: "new row for relation
"test" violates check constraint "enforce_geotype_geom_test""
If you have any idea thank you very much.
Meryem
2010/5/4 Hermann Karl <Karl.Hermann at dornbirn.at>
	Hi Meryem,
	With the logged FdoPg33L vor AutoCAD Map 3d 2009 on
	http://www.geomapgis.com/web/geomap-group/fdo/index.html
	in the LogFile from PostgreSQL you can see whats going on
	Karl
boukhari
	Gesendet: Dienstag, 04. Mai 2010 10:54
	Hi Karl,
	I have tried what you have said but it doesn't work, i got the
same message. I really don't khow why i still have this problem.
	I tried with privileges in the postgis database and it doesn't
work neither.
	Pls can you help me, i don't khow what to do and i am very
pressed
	thx very much
		Hy Meryem,
		look at this link may be it will help
http://lists.osgeo.org/pipermail/fdo-users/2009-September/001812.html
		Karl
boukhari
		Gesendet: Montag, 03. Mai 2010 17:47
		An: fdo-users at lists.osgeo.org
		Betreff: [fdo-users] Autocad map 3D 2009, bulk copy
		Hi every body, i am new user to this mailing list and i
want someone to help me please it's a little bit urgent
		So i want to insert data from shapefile (ESRI) to my
database in postgis 1.3.3, when using bulk copy with Autocad map 3D 2009
i get this message
		"Attempted to read or write protected memory.This is
often an indication that other memory is corrupt".I granted all
necesseray privileges to the user but still the same problem.
		Pls help me and thank you so much.
		fdo-users mailing list
		http://lists.osgeo.org/mailman/listinfo/fdo-users
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20100504/28b67246/attachment-0001.html
More information about the fdo-users mailing list
