[fdo-users] Autocad map 3D 2009, bulk copy
meryem el boukhari meryem.elboukhari at gmail.com
Tue May 4 06:41:58 EDT 2010
Hi Karl,
Thank you very much for your help
It works and i can insert data to the table in postgis, althow at the end i
got the same message"Attempted to read or write protected memory" but When i
check in postgis i have the values inserted and i can visualised data in
Autocad map 3D 2009.
I guess it's not a problem
Meryem
2010/5/4 Hermann Karl <Karl.Hermann at dornbirn.at>
>  Hi Meryem,
> look at this link
> http://lists.osgeo.org/pipermail/fdo-users/2009-July/001736.html
> compare AddGeometryColumn in Case 1 (MULTIPOLYGON) with AddGeometryColumn
> Case 3 (GEOMETRY)
> Karl
> *Von:* fdo-users-bounces at lists.osgeo.org [mailto:
> fdo-users-bounces at lists.osgeo.org] *Im Auftrag von *meryem el boukhari
> *Gesendet:* Dienstag, 04. Mai 2010 11:39
> *An:* FDO Users Mail List
> *Betreff:* Re: [fdo-users] Autocad map 3D 2009, bulk copy
>  Hi Karl,
> Sorry for the disturbance, thank you for your answer.
> In the logfile from postgresql i got this error: "new row for relation
> "test" violates check constraint "enforce_geotype_geom_test""
> If you have any idea thank you very much.
> Meryem
>>  Hi Meryem,
>> With the logged FdoPg33L vor AutoCAD Map 3d 2009 on
>> http://www.geomapgis.com/web/geomap-group/fdo/index.html
>> in the LogFile from PostgreSQL you can see whats going on
>> Karl
>> *Gesendet:* Dienstag, 04. Mai 2010 10:54
>>   Hi Karl,
>> I have tried what you have said but it doesn't work, i got the same
>> message. I really don't khow why i still have this problem.
>> I tried with privileges in the postgis database and it doesn't work
>> neither.
>> Pls can you help me, i don't khow what to do and i am very pressed
>> thx very much
>>>  Hy Meryem,
>>> look at this link may be it will help
>>> http://lists.osgeo.org/pipermail/fdo-users/2009-September/001812.html
>>> Karl
>>> *Gesendet:* Montag, 03. Mai 2010 17:47
>>> *An:* fdo-users at lists.osgeo.org
>>> *Betreff:* [fdo-users] Autocad map 3D 2009, bulk copy
>>>   Hi every body, i am new user to this mailing list and i want someone
>>> to help me please it's a little bit urgent
>>> So i want to insert data from shapefile (ESRI) to my database in postgis
>>> 1.3.3, when using bulk copy with Autocad map 3D 2009 i get this message
>>> "Attempted to read or write protected memory.This is often an indication
>>> that other memory is corrupt".I granted all necesseray privileges to the
>>> user but still the same problem.
>>> Pls help me and thank you so much.
>>> fdo-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/fdo-users
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20100504/3eb15857/attachment.html
More information about the fdo-users mailing list
