[fdo-users] Re: arcsde connection
Brad Nesom kidsmake6 at msn.com
Tue May 4 10:28:27 EDT 2010
Thank you all for the attention to my problem.
 I already had accomplished all the suggestions made. It seems as though
when the sde: or sde:sqlserver: is added to the front of the instance name
the security is circumvented. If I add either one. and then go to login I
can type in "any" username/password combination and I don't get an error. It
returns to the connection screen and shows the datastore empty. If I remove
the sde: then "ANY" combination of the correct username/password returns an
error: "The specified credentials ar not valid or the provider is unable to
establish a connection".
As I said placing sde:sqlserver: in the instance name causes a successful
login (every time) but the datastore is not populated. If I type in my
datastore name and hit connect I get an error message dialog from map.
"failed to open fdo connection, failed to open ArcSDE connection, the file
path des not exist, or it is too long (> 512 chars), or has invalid
characters. (-269). I have seen this and noticed that the datastore name
cannot have a - (dash) in it. Could this apply to the machine name also? Our
IT dept has the computer name set to domain-assetnumber. Mine being
Hiland-FPS93M1.
Thanks again for any help provided.
Brad
On Mon, May 3, 2010 at 8:10 PM, Jackie Ng <jumpinjackie at gmail.com> wrote:
> The ArcSDE provider doesn't do direct connections, it goes through the
> official ESRI SDE API.
> There was talk about a direct connect ArcSDE provider, but AFAIK this only
> works with Oracle and I haven't heard much more about this provider since.
> - Jackie
> http://osgeo-org.1803224.n2.nabble.com/arcsde-connection-tp5000154p5001172.html
> Sent from the FDO Users mailing list archive at Nabble.com.
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
> Brad,
Have you seen the help here which provides the connection syntax for the
ESRI direct SDK connection?
http://trac.osgeo.org/fdo/wiki/FdoArcSDEDirectConnect
As far as the non-SDK provider (arguably poorly named with "Direct" in the
name) it only connects to SDE stores in Oracle.  See
http://trac.osgeo.org/fdo/wiki/FDORfc42 for details though the algorithms
and logic would be transportable to the SQLServer provider if funded.
http://osgeo-org.1803224.n2.nabble.com/arcsde-connection-tp5000154p5002138.html
- Show quoted text -
Hi Brad,
For direct connect to SQL 2008, set the server name for the server running
SQL 2008 and use an instance name of:
       sde:sqlserver:<servername>\instancename
Note that for direct connect, you need the sde direct connect libraries. Put
the following dll's into your fdo bin directory (assuming that you are using
sde 9.3):
       gsrvrsql93.dll , sdesqlsrvr93.dll , xerces-c_2_7.dll , icuuc22.dll ,
and icudt22l.dll
Thanks,
Orest.
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20100504/015aa948/attachment.html
More information about the fdo-users mailing list
