[fdo-users] King Oracle join performance
Jason Birch jason at jasonbirch.com
Thu May 13 18:12:50 EDT 2010
You can use the KingFdoClass table to do this (it doesn't support xml
configuration-based class definitions)
http://www.sl-king.com/fdooracle/KingFdoClass.htm
Jason
On 13 May 2010 11:50, Romica Dascalescu wrote:
> I think MGOS it has an internal module for joins and is not using Oracle
> join. So I think server is getting all data and is doing 'client' side
> joins.
> I think there is a way to avoid that (but I'm not sure King provider
> supports that), is to create a view based on your join and expose that view
> as a feature class. This way your view will be like a read-only class.
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20100513/2c48ed5b/attachment.html
More information about the fdo-users mailing list
