[fdo-users] FDO 3.5 with Map 3D 2010
adrian hedley adrian.hedley at enemalta.com.mt
Tue May 18 05:41:03 EDT 2010
I have tried to use the 3.5 version of the FDO on map 3D and i am getting
the following errors:
Unable to create connection to provider 'OSGeo.SQLServerSpatial.3.5'
Unable to load the FDO Provider: The specified procedure could not be found
I do not know if it is possible to use version 3.5 on Map 3D 2010, however
this is important since there is a resolved bug in this version. The bug is
related to an infinite loop when using triggers in Sqlserver
(http://trac.osgeo.org/fdo/ticket/507)
It wold be great if i could have a version of an FDO with issue 507 solved
that works with map 3d 2010.
Regards,
Adrian Hedley
View this message in context: http://osgeo-org.1803224.n2.nabble.com/FDO-3-5-with-Map-3D-2010-tp5069208p5069208.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
