[fdo-users] ArcSDE personal connect
Jack Lee jack.lee at sympatico.ca
Sun May 23 23:58:20 EDT 2010
Hi Brad,
You should use the ArcSDE provider.
For the instance name, did you use sde:myserver\sqlexpress or
sde:sqlserver:myserver\sqlexpress?
On 5/21/2010 9:26 AM, Brad Nesom wrote:
> I have been trying to make an autocad map (2010, 2011) connection to
> sql2008 express with an arcsde 9.3.1 personal gdb. I get several
> reactions depending on which connection and the values I use. I tried
> going through autodesk support to get a resolution. I got the
> following response from them. I have seen some responses on this forum
> expressing that the connection is possible. Any help would be appreciated.
> Brad
> My connection parameters...
> sql server spatial
> service name:              sde:sqlsserver:myserver\sqlexpress
> response:                    credentials are not valid or provider is
> unable to establish a connection.
> ArcSDE connection
> server name:                myserver\sqlexpress
> instance name:            sde:myserver\sqlexpress
> response:                   no error on credentials but the data store
> not populated
> the sde:sqlserver:myserver\SQLEXPRESS syntax works in FME and returns
> the geometry correctly
> Autodesk Response ...
> Here's the official word from the product manager:
> This is not a supported configuration. Not tested. I suspect the
> "local connect" string is not understood by our provider.  But even if
> Map 3D did connect, you wouldn’t be able to "create a datastore". FDO
> Provider for ArcSDE doesn’t allow creation of data store from Map 3D.
> you can only connect and edit existing ArcSDE Data Stores.
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20100523/0804bef8/attachment.html
More information about the fdo-users mailing list
