[fdo-users] Problems with FDO: PostGIS Provider
Greg Boone greg.boone at autodesk.com
Mon May 31 10:39:10 EDT 2010
I recommend switching to use the FDO PostgreSQL Provider. The PostGIS Provider is no longer being supported.
Greg
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of hanko
Sent: Monday, May 31, 2010 8:48 AM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] Problems with FDO: PostGIS Provider
Hi all,
I'm using the FDO PostGIS  ("OSGeo.PostGIS.3.5") provider to connect to my
PostGreSQL 8.4 + Postgis database.
The database encoding is UTF-8, Current Culture of my application is
{sv-SE},  but when i try to create a new FeatureSchema with
FeatureClass.Name = "Örebrö" and PropertyDefinition property.Name =
"Operatör" the schema is created with incorrect characters and I get an
exception.
It seems that PostGIS provider has problem with locale-dependent string
conversion.
In phpPgAdmin I can see:
"SQL Error:
ERROR:  invalid byte sequence for encoding "UTF8": 0xe39672
HINT:  This error can also happen if the byte sequence does not match the
encoding expected by the server, which is controlled by "client_encoding"."
Any ideas?
Thank in advance
Hanko
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Problems-with-FDO-PostGIS-Provider-tp5121665p5121665.html
Sent from the FDO Users mailing list archive at Nabble.com.
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users mailing list
