[fdo-users] Re: FDO 3.5 ArcSDE Provider Oracle ORA-00920
Romica Dascalescu Romica.Dascalescu at autodesk.com
Wed Nov 3 12:19:22 EDT 2010
Hi Henning,
I had a look at your change and it's OK, however I would propose some additional changes to remove class FilterAnalyzer and flags mFilterAnalyzed, mUseNesting.
This will simplify the code and will make possible use less brackets in a filter. The same method is used in FDO & SQLite filter ToString in order to avoid too many brackets.
I attached a code change (ArcSDE.patch) to the ticket (http://trac.osgeo.org/fdo/ticket/719).
Could you please have a loot at the code change proposed and test it if possible and let me know your opinion?
Regards,
Romy.
________________________________________
From: fdo-users-bounces at lists.osgeo.org [fdo-users-bounces at lists.osgeo.org] on behalf of maland [hma at powel.com]
Sent: Wednesday, November 03, 2010 4:34 AM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] Re: FDO 3.5 ArcSDE Provider Oracle ORA-00920
I have debugged the ArcSDE provider source and identified the problem. It
seems to be related to the "nesting" in function
ArcSDEFilterToSql::ProcessBinaryLogicalOperator. It happens when both
operands are "attribute"-style filters. The parenthesis matching is broken.
Where can I post the bugfix proposal so it can be included in the next
release?
Regards
Henning Maeland
oyvind idland wrote:
> I get the same problem here.
> It seems to me that the SQL generator goes a bit too far in wrapping
> everything in parenthesis ?
> Unfortunately it seems that the SDE provider is currently broken.
> -- Oyvind
> On Fri, Oct 1, 2010 at 10:27 AM, maland <hma at powel.com> wrote:
>> I've been able to find the SQL generated by the ArcSDEFilterToSql class,
>> and
>> there is obviously a problem with the parantheses matching. Example of
>> SQL
>> generated:
>> SELECT  XROW, YROW FROM EXAMPLE_POINTS WHERE YROW = 0  AND  ( ( ( (XROW)
>> (0)  ( OR  ( (XROW)  =  (1) ) ) )
>> Hopefully the authors of the FDO ArcSDE provider can have a look at this?
>> Regards
>> Henning
>> View this message in context:
>> http://osgeo-org.1803224.n2.nabble.com/FDO-3-5-ArcSDE-Provider-Oracle-ORA-00920-tp5587468p5590547.html
>> Sent from the FDO Users mailing list archive at Nabble.com.
>> fdo-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/fdo-users
View this message in context: http://osgeo-org.1803224.n2.nabble.com/FDO-3-5-ArcSDE-Provider-Oracle-ORA-00920-tp5587468p5700469.html
More information about the fdo-users mailing list
