[fdo-users] FDO VC 2008 - Compilation Issue
Romica Dascalescu Romica.Dascalescu at autodesk.com
Fri Nov 19 11:12:14 EST 2010
Hello Ela,
Could you please tell me if you have installed ActiveState Perl, available from http://www.activestate.com/ActivePerl ?
Build steps can be found in OpenSourceBuild__README.txt
Regards,
Romy.
From: fdo-users-bounces at lists.osgeo.org [fdo-users-bounces at lists.osgeo.org] on behalf of Elavazhagan. M [elavazhagan.mouniandy at kcubeconsulting.com]
Sent: Friday, November 19, 2010 10:33 AM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] FDO VC 2008 - Compilation Issue
Hello List,
I am trying to build FDO and Providers using VC 2008. I was able to compile third_party DLLs. But after that when I compile fdo using build.bat I am getting the following error:
error PRJ0019: A tool returned an error code from "Performing Custom
Build Step:  Creating GRFPMessage.h and RFPMessage.rc from GRFPMessage.mc"
Please not that I have already tried vcvars32.bat and vsvars32.bat with no success.
Detailed output from the command prompt:
C:\Test\fdo\OpenSource_FDO>build
Build release Fdo dlls
Build started 11/19/2010 8:53:41 PM.
Project "C:\Test\fdo\OpenSource_FDO\Fdo\FDO.sln" on node 0 (Build target(s)).
  Building solution configuration "release|Win32".
Message:
  Deleting file "C:\Test\fdo\OpenSource_FDO\Fdo\Unmanaged\Message.tmp_Release_W
  in32.vcproj".
Common:
  Deleting file "C:\Test\fdo\OpenSource_FDO\Fdo\Unmanaged\Common.tmp_Release_Wi
  n32.vcproj".
Geometry:
  Deleting file "C:\Test\fdo\OpenSource_FDO\Fdo\Unmanaged\Geometry.tmp_Release_
  Win32.vcproj".
MgCommon:
  Deleting file "C:\Test\fdo\OpenSource_FDO\Fdo\Managed\Project\MgCommon.tmp_Re
  lease_Win32.vcproj".
Spatial:
  Deleting file "C:\Test\fdo\OpenSource_FDO\Fdo\Unmanaged\Spatial.tmp_Release_W
  in32.vcproj".
MgGeometry:
  Deleting file "C:\Test\fdo\OpenSource_FDO\Fdo\Managed\Project\MgGeometry.tmp_
  Release_Win32.vcproj".
Fdo:
  Deleting file "C:\Test\fdo\OpenSource_FDO\Fdo\Unmanaged\Fdo.tmp_Release_Win32
  .vcproj".
MgFDO:
  Deleting file "C:\Test\fdo\OpenSource_FDO\Fdo\Managed\Project\MgFDO.tmp_Relea
  se_Win32.vcproj".
MgSpatial:
  Deleting file "C:\Test\fdo\OpenSource_FDO\Fdo\Managed\Project\MgSpatial.tmp_R
UnitTest:
  Deleting file "C:\Test\fdo\OpenSource_FDO\Fdo\UnitTest\UnitTest.tmp_Release_W
  in32.vcproj".
Done Building Project "C:\Test\fdo\OpenSource_FDO\Fdo\FDO.sln" (Build target(s)
Build succeeded.
Time Elapsed 00:02:39.75
End FDO Build
Build release GdalFile provider dlls
Microsoft (R) Windows Script Host Version 5.6
Copyright (C) Microsoft Corporation 1996-2001. All rights reserved.
Build started 11/19/2010 8:56:24 PM.
Project "C:\Test\fdo\OpenSource_FDO\Providers\GDAL\Src\RFP_temp.sln" on node 0
(Build target(s)).
Project : error PRJ0019: A tool returned an error code from "Performing Custom
Done Building Project "C:\Test\fdo\OpenSource_FDO\Providers\GDAL\Src\RFP_temp.s
ln" (Build target(s)) -- FAILED.
Build FAILED.
Time Elapsed 00:00:01.93
There was a build error executing action: Build
There was a build error.
Any help? Thanks in advance.
Regards,
Ela.
More information about the fdo-users mailing list
