[fdo-users] FDO VC 2008 - Compilation Issue
Elavazhagan. M elavazhagan.mouniandy at kcubeconsulting.com
Mon Nov 22 11:42:05 EST 2010
Hello Romy,
Here are some more supplementary information. When I try to build the shp
provider alone, I am getting the below error. (I was trying in another
machine, that is the reason for the change of the source directory)
C:\OpenSource>build -w=shp
Build release SHP provider dlls
Build started 11/22/2010 10:18:37 PM.
Project "C:\OpenSource\Providers\SHP\Src\SHP_temp.sln" on node 0 (Build
target(
s)).
  Building solution configuration "release|Win32".
C:\OpenSource\Fdo\Unmanaged\inc\Common/Exception.h(26): fatal error C1083:
Cann
ot open include file: 'FdoMessage.h': No such file or directory
Cann
Done Building Project "C:\OpenSource\Providers\SHP\Src\SHP_temp.sln" (Build
tar
get(s)) -- FAILED.
Build FAILED.
Time Elapsed 00:00:10.31
There was a build error executing action: Build
There was a build error.
Any help?
Thanks,
Ela.
> -----Original Message-----
> From: Elavazhagan. M [mailto:elavazhagan.mouniandy at kcubeconsulting.com]
> Sent: Monday, November 22, 2010 11:18 AM
> To: 'FDO Users Mail List'
> Subject: RE: [fdo-users] FDO VC 2008 - Compilation Issue
> Hello Romy,
> Yes, I do have ActivePerl installed to C:\Perl. Also, I am following
> only OpenSourceBuild__README.txt to build FDO.
> Do you have any other clue?
> Thanks,
> Ela.
> > From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-
> > bounces at lists.osgeo.org] On Behalf Of Romica Dascalescu
> > Sent: Friday, November 19, 2010 9:42 PM
> > To: FDO Users Mail List
> > Hello Ela,
> > Could you please tell me if you have installed ActiveState Perl,
> > available from http://www.activestate.com/ActivePerl ?
> > Build steps can be found in OpenSourceBuild__README.txt
> > Regards,
> > Romy.
> > ________________________________
> > From: fdo-users-bounces at lists.osgeo.org [fdo-users-
> > bounces at lists.osgeo.org] on behalf of Elavazhagan. M
> > [elavazhagan.mouniandy at kcubeconsulting.com]
> > Sent: Friday, November 19, 2010 10:33 AM
> > To: fdo-users at lists.osgeo.org
> > Subject: [fdo-users] FDO VC 2008 - Compilation Issue
> > Hello List,
> > I am trying to build FDO and Providers using VC 2008. I was able to
> > compile third_party DLLs. But after that when I compile fdo using
> > build.bat I am getting the following error:
> > error PRJ0019: A tool returned an error code from "Performing Custom
> > Build Step:  Creating GRFPMessage.h and RFPMessage.rc from
> > GRFPMessage.mc"
> > Please not that I have already tried vcvars32.bat and vsvars32.bat
> with
> > no success.
> > Detailed output from the command prompt:
> > C:\Test\fdo\OpenSource_FDO>build
> > Build release Fdo dlls
> > Build started 11/19/2010 8:53:41 PM.
> > Project "C:\Test\fdo\OpenSource_FDO\Fdo\FDO.sln" on node 0 (Build
> > target(s)).
> > Message:
> >   Deleting file
> > "C:\Test\fdo\OpenSource_FDO\Fdo\Unmanaged\Message.tmp_Release_W
> >   in32.vcproj".
> > Common:
> >   Deleting file
> > "C:\Test\fdo\OpenSource_FDO\Fdo\Unmanaged\Common.tmp_Release_Wi
> >   n32.vcproj".
> > Geometry:
> >   Deleting file
> > "C:\Test\fdo\OpenSource_FDO\Fdo\Unmanaged\Geometry.tmp_Release_
> >   Win32.vcproj".
> > MgCommon:
> >   Deleting file
> > "C:\Test\fdo\OpenSource_FDO\Fdo\Managed\Project\MgCommon.tmp_Re
> >   lease_Win32.vcproj".
> > Spatial:
> >   Deleting file
> > "C:\Test\fdo\OpenSource_FDO\Fdo\Unmanaged\Spatial.tmp_Release_W
> >   in32.vcproj".
> > MgGeometry:
> >   Deleting file
> > "C:\Test\fdo\OpenSource_FDO\Fdo\Managed\Project\MgGeometry.tmp_
> >   Release_Win32.vcproj".
> > Fdo:
> >   Deleting file
> > "C:\Test\fdo\OpenSource_FDO\Fdo\Unmanaged\Fdo.tmp_Release_Win32
> >   .vcproj".
> > MgFDO:
> >   Deleting file
> > "C:\Test\fdo\OpenSource_FDO\Fdo\Managed\Project\MgFDO.tmp_Relea
> >   se_Win32.vcproj".
> > MgSpatial:
> >   Deleting file
> > "C:\Test\fdo\OpenSource_FDO\Fdo\Managed\Project\MgSpatial.tmp_R
> > UnitTest:
> >   Deleting file
> > "C:\Test\fdo\OpenSource_FDO\Fdo\UnitTest\UnitTest.tmp_Release_W
> >   in32.vcproj".
> > Done Building Project "C:\Test\fdo\OpenSource_FDO\Fdo\FDO.sln" (Build
> > target(s)
> > Build succeeded.
> > Time Elapsed 00:02:39.75
> > End FDO Build
> > Build release GdalFile provider dlls
> > Microsoft (R) Windows Script Host Version 5.6
> > Copyright (C) Microsoft Corporation 1996-2001. All rights reserved.
> > Build started 11/19/2010 8:56:24 PM.
> > Project "C:\Test\fdo\OpenSource_FDO\Providers\GDAL\Src\RFP_temp.sln"
> on
> > node 0
> > (Build target(s)).
> > Project : error PRJ0019: A tool returned an error code from
> "Performing
> > Custom
> > GRFPMessage.mc"
> > ln" (Build target(s)) -- FAILED.
> > Build FAILED.
> > Time Elapsed 00:00:01.93
> > Any help? Thanks in advance.
> > Regards,
> > Ela.
> > fdo-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users mailing list
