[fdo-users] Tool for editing f_ tables in SQL 2008?
Srecko Lipovsek srecko.lipovsek at kaliopa.si
Tue Oct 26 05:40:46 EDT 2010
Hi
We store all spatial data in SQL 2008. All DB-s also includes f_ tables for
describing Schemas and Clases.
We realize that f_ tables are now optional in SQL 2008, but they are great
because they provide clean and organized data.
The only problem when using f_ tables is how to add new feature class from
new table or some view.
When we import data to SQL with non FDO provider, only table is created and
f_ tables are not populated. Also when some new view is created, we have
manualy populate f_ tables if we want to view data. When one new column on
existing class is created also something with f_ tables, ... there is many
cases when manualy editing of f_ tables should be done to corectly view data
 We know, that with some tricks (copy data from one to another DB with no f_
tables and back) should work, but I think that TOOL or PROCEDURE should be
the best way for reading psyihical SQL objects maping and writing it to f_
tables (and also checker if something is deleted) ...
Editing f_ tables by hand is very tricky, so:
1.) I'am wondering if there is some TOOL or SQL PROCEDURE for editing
(check, read, write) f_ tables in SQL 2008 (SQL objects phyisical mapping to
f_ tables and vice versa)?
2.) Whether this can be done via the FDO API?
3.) Is there any DOCUMENTATION for f_ tables?
Srecko Lipovsek, BSc Civil Engineer
Kaliopa d.o.o., Ljubljana, Slovenija
WWW:  http://www.Kaliopa.si www.Kaliopa.si   |  http://www.iObcina.si
www.iObcina.si  |  http://gis.iObcina.si gis.iObcina.si  |
http://www.iSlovenija.si www.iSlovenija.si  |  http://www.iKomunala.si
www.iKomunala.si
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Tool-for-editing-f-tables-in-SQL-2008-tp5673979p5673979.html
Sent from the FDO Users mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20101026/646ef7c0/attachment.html
More information about the fdo-users mailing list
