[fdo-users] Re: Tool for editing f_ tables in SQL 2008?
Dan Stoica dan.stoica at autodesk.com
Tue Oct 26 19:18:22 EDT 2010
Ø  Are they populated from some ENUMs, CONSTANTs or are they calculated somehow?
Yes, they are bitmapped values as follows:
a)      attributetype column stores the geometric type:
FdoGeometricType
enum FdoGeometricType
    /// Represents 0-dimensional geometric primitives, such as Points.
    FdoGeometricType_Point = 0x01,
    /// Represents 1 dimensional geometric primitives, such as Curves and Lines.
    FdoGeometricType_Curve = 0x02,
    /// Represents 2 dimensional geometric primitives, such as Polygons.
    FdoGeometricType_Surface = 0x04,
    /// Represents 3 dimensional geometric primitives, such as Cubes.
    FdoGeometricType_Solid = 0x08
b)  geometrytype column stores the geometry type:
enum FdoGeometryTypeHexCode
    FdoGeometryTypeHexCode_None              = 0x00020,
    FdoGeometryTypeHexCode_Point             = 0x00040,
    FdoGeometryTypeHexCode_LineString        = 0x00080,
    FdoGeometryTypeHexCode_Polygon           = 0x00100,
    FdoGeometryTypeHexCode_MultiPoint        = 0x00200,
    FdoGeometryTypeHexCode_MultiLineString   = 0x00400,
    FdoGeometryTypeHexCode_MultiPolygon      = 0x00800,
    FdoGeometryTypeHexCode_MultiGeometry     = 0x01000,
    FdoGeometryTypeHexCode_CurveString       = 0x02000,
    FdoGeometryTypeHexCode_CurvePolygon      = 0x04000,
    FdoGeometryTypeHexCode_MultiCurveString  = 0x08000,
    FdoGeometryTypeHexCode_MultiCurvePolygon = 0x10000,
Check for example how the geometrytype is computed from user's input:
FdoGeometricPropertyDefinition::SetSpecificGeometryTypes(FdoGeometryType *types, FdoInt32 length)
Regerds,
Dan.
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Srecko Lipovsek
Sent: Tuesday, October 26, 2010 5:50 PM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] Re: Tool for editing f_ tables in SQL 2008?
Wow, thanks for quick answer ... and special for attached document ...
This document is very helpful and explain a lot.
I can't still figure out meaning of columns attributetype and geometrytype in table f_attributedefinition
>From your document:
attributetype = FDO property type.
geometrytype = Detailed geometry types allowed for this column.
Here are some of the values from table f_atributedefinition from different databases
Works with
columntype
attributetype
geometrytype
Point
geometry
1
576
Point
geometry
1
64
Line or..
geometry
2
42112
Line or..
geometry
7
126912
Line or..
geometry
2
1152
Polygon or..
geometry
4
256
Polygon or..
geometry
4
84224
Srecko Lipovsek
Kaliopa d.o.o., Ljubljana, Slovenija
View this message in context: Re: Tool for editing f_ tables in SQL 2008?<http://osgeo-org.1803224.n2.nabble.com/Tool-for-editing-f-tables-in-SQL-2008-tp5673979p5676696.html>
Sent from the FDO Users mailing list archive<http://osgeo-org.1803224.n2.nabble.com/FDO-Users-f2048584.html> at Nabble.com.
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20101026/2918ce06/attachment-0001.html
More information about the fdo-users mailing list
