[fdo-users] IApplySchema using King Oracle provider with BLOB field
Haris Kurtagic haris at sl-king.com
Wed Oct 27 08:02:42 EDT 2010
Hi Paul,
I have just checked in provider and yes it is missing BLOB creation
trough apply schema command.
I recently added support for BLOB in King.Oracle and it seems "forgot"
to implement  in apply  schema as well.
I don't have time to do tests, but if you would test it i could
implement it right away and let you try it.
I would need your FDO version and platform 32/64 to send you specific
version to test.
Haris
On Wed, Oct 27, 2010 at 1:43 PM, GISkit_Paul <paul at giskit.nl> wrote:
> Hello,
> I am trying to apply a schema in Oracle using de King Oracle Provider for
> FDO. My schema consists of one field with the datatype BLOB, which I want to
> use to store attributedata as a byte-array.
> I get an exception at the 'Execute' method for IApplySchema stating:
> 'Exception: OSGeo.FDO.Common.Exception OSGeo.FDO.Common.Exception:
> c_KgOraApplySchema::Execute: Unkown Property Definition at
> OSGeo.FDO.Commands.Schema.IApplySchemaImp.Execute()'
> When I leave out the BLOB-field it works fine. Also, if I manually add a
> BLOB-field to the created table, I can store BLOB data using the same
> provider. Has anyone an idea what is going wrong?
> Regards,
> Paul
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/IApplySchema-using-King-Oracle-provider-with-BLOB-field-tp5678225p5678225.html
> Sent from the FDO Users mailing list archive at Nabble.com.
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users mailing list
