[fdo-users] Re: Tool for editing f_ tables in SQL 2008?
Srecko Lipovsek srecko.lipovsek at kaliopa.si
Fri Oct 29 05:31:16 EDT 2010
Thanks a lot for detailed explanation ...
This IS IT, now everything is understandable.
We will now probably write small .NET application for mapping classes and
properties betwen psyihical SQL schema mapping to f_ tables + checker in
both sides if something is droped + ...
Below is attached meaning of those two attriibutes calculated in decimal
form if somebody search forum or need:
Code is in
D:\FDO_branches\3.5\Fdo\Unmanaged\Src\Fdo\Schema\GeometricPropertyDefinition.cpp
also if somebody search ...
Thanks again ...
                Basic geometry
                geometrytype
                attributetype
                FdoGeometryTypeHexCode_None
                32
                FdoGeometryTypeHexCode_Point
                64
                1
                FdoGeometryTypeHexCode_LineString
                128
                2
                FdoGeometryTypeHexCode_Polygon
                256
                4
                FdoGeometryTypeHexCode_MultiPoint
                512
                1
                FdoGeometryTypeHexCode_MultiLineString
                1024
                2
                FdoGeometryTypeHexCode_MultiPolygon
                2048
                4
                FdoGeometryTypeHexCode_MultiGeometry
                4096
                4
                FdoGeometryTypeHexCode_CurveString
                8192
                2
                FdoGeometryTypeHexCode_CurvePolygon
                16384
                4
                FdoGeometryTypeHexCode_MultiCurveString
                32768
                2
                FdoGeometryTypeHexCode_MultiCurvePolygon
                65536
                4
                Combinations (sum of above values)
                All_GEOMETRY_POINT
                576
                1
                LINESTRING_MULTILINESTRING
                1152
                2
                POLYGON_MULTIPOLYGON
                2304
                4
                ALL_GEOMETRY_CURVE
                42112
                2
                ALL_GEOMETRY_SURFACE
                84224
                4
                ALL_GEOMETRY_POINT_CURVE
                42688
                3
                ALL_GEOMETRY_POINT_SURFACE
                84800
                5
                ALL_GEOMETRY_CURVE_SURFACE
                126336
                6
                ALL_GEOMETRY_POINT_CURVE_SURFACE
                126912
                7
Srecko Lipovsek
Kaliopa d.o.o., Ljubljana, Slovenija
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Tool-for-editing-f-tables-in-SQL-2008-tp5673979p5685741.html
Sent from the FDO Users mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20101029/71f5a57d/attachment.html
More information about the fdo-users mailing list
