[fdo-users] Problem with FDO King Oracle Provider - unable to load library
Riccardo Pucci riccardo.pucci at gruppoesc.it
Fri Aug 19 04:44:04 EDT 2011
Hi
Because of bug http://trac.osgeo.org/fdo/ticket/562 KingOracle provider
does not work under linux... I made some progress trying to fix it for
MGOS 2.2 but still have some problem.
Riccardo
Il 19/08/2011 09:45, Jan Ma?ysiak ha scritto:
> Thanks for all your replies,
> @ Zac:
> On SL-King website I can see only downloads for Windows, I am using
> Ubuntu.
> @ dblackbeer and Simon:
> I use provider downloaded in a packed archive from here:
> http://download.osgeo.org/mapguide/releases/2.1.0/fdosdk-centos5-3.4.1.5452.tgz
> so I think it should work on Linux as well. Other providers seem to
> work fine, anyway all Oracle providers (I've tried OGR and ODBC) have
> some problem with connection, I get 559 MgFdoException error.
> Best regards,
> Jan Ma?ysiak
> 2011/8/19 Simon Pelicon <simon at sl-king.com <mailto:simon at sl-king.com>>
>     Hi!
>     We do not have King Oracle Provide for Linux.
>     You have to use provider that comes with the MapGuide instalation.
>     Try using Oracle Instant Client for Oracle 10g or 11g
>     Simon
>     On Fri, Aug 19, 2011 at 5:06 AM, Zac Spitzer
>     <zac.spitzer at gmail.com <mailto:zac.spitzer at gmail.com>> wrote:
>         try using the latest version of King Oracle
>         http://www.sl-king.com/fdooracle/download/download.html
>         On Fri, Aug 19, 2011 at 10:37 AM, dblackbeer
>         <dblackbeer at gmail.com <mailto:dblackbeer at gmail.com>> wrote:
>         > On 18 August 2011 19:09, Jan Ma?ysiak
>         <j.malysiak at hotmail.com <mailto:j.malysiak at hotmail.com>> wrote:
>         >> Hi all,
>         >> I am not able to connect to Oracle database using King
>         Oracle Provider. I'm
>         >> trying to establish the connection in MapGuide Maestro, but
>         I receive a long
>         >> message of an error, where I think the most important part is
>         >> "CLNT_8_UNABLE_TO_LOAD_LIBRARY". The same appears in the
>         error log, and the
>         >> same in mapagent when I try to get capabilities for King
>         Oracle Provider.
>         >> I've already found several descriptions of similar problems
>         posted by other
>         >> users, but unfortunately none of them solved my problem. I
>         have added the
>         >> provider entry in providers.xml file, downloaded Oracle
>         Instant Client,
>         >> added its path to LD_LIBRARY_PATH, checked dependencies for
>         >> libKingOracleProvider.so, copied required Oracle libraries
>         to FDO/lib
>         >> directory, now when I run ldd command for the
>         libKingOracleProvider.so it
>         >> says that all required libraries are found, nevertheless
>         the error
>         >> establishing new connection still occurs.
>         >> I use:
>         >> MapGuide Open Source 2.1.0
>         >> FDO 3.4.0
>         >> MapGuide Maestro 2.1.4
>         >> Ubuntu 10.10
>         >> Oracle Instant Client 10.2.0.4
>         >> I'm not sure of the version of King Oracle Provider as I
>         downloaded it in an
>         >> archive together with other FDO providers.
>         >> I would be very thankful for any help.
>         >> Best regards,
>         >> Jan Ma?ysiak
>         >> _______________________________________________
>         >> fdo-users mailing list
>         >> fdo-users at lists.osgeo.org <mailto:fdo-users at lists.osgeo.org>
>         >> http://lists.osgeo.org/mailman/listinfo/fdo-users
>         > King Oracle Provider it doesn't supported under linux.
>         > dblackbeer
>         Zac Spitzer
>         Solution Architect / Director
>         Ennoble Consultancy Australia
>         http://www.ennoble.com.au
>         http://zacster.blogspot.com
>         +61 405 847 168 <tel:%2B61%20405%20847%20168>
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20110819/0a7c8206/attachment-0001.html
More information about the fdo-users mailing list
