[fdo-users] FDO OSGeo.OGR can read DXF Files ??
Wed Aug 24 18:21:28 EDT 2011
Carlos,
You have not been very specific about what version of FDO you
are using.  The DXF driver in OGR is *relatively* recent, and even
if you are using the latest development version of FDO it may not
include a sufficiently recent GDAL/OGR version to include the DXF.
If you are using an older version of FDO then it is even more likely
it does not include DXF support.
Digging around I see FDO 3.6 does include DXF support:
http://svn.osgeo.org/fdo/branches/3.6/Thirdparty/gdal/ogr/ogrsf_frmts/dxf/
I see that FDO 3.5 does *not* include DXF support.
While a bit risky and complicated, it should be possible to back port
newer GDAL/OGR's or even just the DXF driver into an older FDO.
Best regards,
Frank
On Wed, Aug 24, 2011 at 2:43 PM, Carlos Lacerda
<carlos.lacerda at gmail.com> wrote:
> Hi folks,
> I searched in all sources i know, about, how to use "FDO Provider
> OSGeo.OGR" on "MapGuide OpenSource" to read a DXF file but without
> success :(
> Anyone know if is possible to create a layer on MapGuide using  a
> feature source of type "FDO Provider OSGeo.OGR" ??
> I can´t create a connection to DXF file, this provider runs ok to use
> a Shapefile for example, but when i use a DXF file always get an
> error.
> Anyone has already created a DXF layer on MapGuide ???
> Thanks a lot.
> Sds,
> Carlos Lacerda
> System Architect - CIAS
> Brasil
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
and watch the world go round - Rush    | Geospatial Software Developer
More information about the fdo-users mailing list
