[fdo-users] Enable/Disable spatial indexing in Autodesk FDO Provider for Oracle
Dan Stoica dan.stoica at autodesk.com
Mon Feb 21 12:08:05 EST 2011
I didn't check but I'm pretty sure it is not possible.
How did you reach the conclusion that the spatial indexing is the culprit for slow performance? Insert/update are slow operations anyways. This said and assuming we disable the spatial index, in the end it may not make a significant difference.
Dan.
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Ray
Sent: Monday, February 21, 2011 10:53 AM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] Enable/Disable spatial indexing in Autodesk FDO Provider for Oracle
Each time when I create a feature class with GeometricPropertyDefinition,
spatial indexing is automatically enabled. I wonder if there is a way that
let me enable/disable the spatial indexing.
I need to import a lare dataset using FDO. I wonder if I could disable the
spatial indexing during import but enable it after import so that it could
speed up the import process.
I am using Autodesk FDO provider for Oracle.
Thanks,
Ray
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Enable-Disable-spatial-indexing-in-Autodesk-FDO-Provider-for-Oracle-tp6049141p6049141.html
Sent from the FDO Users mailing list archive at Nabble.com.
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users mailing list
