[fdo-users] Re: Conversion of SQLServer Date type to FDO type Double ?
Bo Victor Thomsen bvt at geograf.dk
Wed Jun 1 06:04:59 EDT 2011
Hi Jackie -
Thanks for taking the time to answer :-)
The FDO toolbox is  absolutely worthy of a closer study. I didn't know
you could change the setup scenario between a datasource and MapGuide
using XML schemas.
Unfortunately it won't solve my problem. My problem is that "Date"
columns from SQL Server is not visible at all in MapGuide  (or the FDO
toolbox). I made a mistake in my first posting, which I corrected  in my
second posting.
A small example:
If you create the following table in SQL Server 2008 R2:
CREATE TABLE [dbo].[test_table](
     [counter] [int] IDENTITY(1,1) NOT NULL,
     [some_date] [date] NULL,
     [some_datetime] [datetime] NULL,
     [some_text] [varchar](50) NULL
and connect this table to MapGuide, the field "some_date" is missing
while the other fields are visible.
I'm using:
MapGuide 2.1,
FDO - MS SQL Server Provider ver. 3.4.1,
SQL Server 2008 R2
Med venlig hilsen
Bo Victor Thomsen
Geograf A/S
Den 01-06-2011 10:44, Jackie Ng skrev:
> Maybe you could use FDO Schema XML configuration to override the default
> logical schema, changing the Fdo Double property to a DateTime one?
> Example with FDO Toolbox:
> http://themapguyde.blogspot.com/2010/09/using-fdo-schema-overrides-redux.html
> - Jackie
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Conversion-of-SQLServer-Date-type-to-FDO-type-Double-tp6418758p6426087.html
> Sent from the FDO Users mailing list archive at Nabble.com.
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users mailing list
