[fdo-users] RE: Compilation on 64-bit linux
Robin Newton robin.newton at 1spatial.com
Thu May 5 04:59:30 EDT 2011
Before I investigate this, I had a couple of questions:
- Do you know which of the providers can't be built like this?
- Is fixing up the cmake build likely to be a matter of common sense
(finding errors and fixing them) or is it likely to require a more in-depth
understanding of changes to the code base since the last time it was
updated?
Thanks,
Robin
Traian Stanev wrote:
> The official Linux build is the automake one.
> Personally, I have had more success with the cmake build on Linux-x86_64,
> but this does not build all of the providers. Since it hasn't been updated
> for some time, the cmake build is also likely a bit out of date.
> Traian
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Compilation-on-64-bit-linux-tp6261771p6333620.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
