[fdo-users] Re: FDO 3.6.0: AccessViolationException in cleanup IGeometry
Ray ray.wu at efacec.com
Fri Oct 21 15:43:32 EDT 2011
Jackie,
I did it as you recommended. The new code is as follows but I still got the
same exception. If I take away "using" statement, it runs fine but it has
memory leak.
I also tried not to use "using" statement but add geometry.Dispose() after
done with the geometry. I got the same exception.
There was not a problem when I used with FDO 3.4.0 in Autocad MAP 3d 2010.
 Using gisGeometry As OSGeo.FDO.Geometry.IGeometry =
agfGeoFactory.CreateGeometryFromFgf(byteArray)
            'Cast the geometry to a position
            Dim myPosition As OSGeo.FDO.Geometry.IPoint
            Dim pos As OSGeo.FDO.Geometry.IDirectPosition
            Dim env As OSGeo.FDO.Geometry.IEnvelope
            If TypeOf gisGeometry Is OSGeo.FDO.Geometry.IPoint Then
                myPosition = gisGeometry
                pos = myPosition.Position
                dInsertionPoint(0) = pos.X
                dInsertionPoint(1) = pos.Y
            Else
                env = gisGeometry.Envelope
                dInsertionPoint(0) = env.MinX
                dInsertionPoint(1) = env.MinY
            End If
        End Using
View this message in context: http://osgeo-org.1803224.n2.nabble.com/FDO-3-6-0-AccessViolationException-in-cleanup-IGeometry-tp6913596p6918297.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
