[fdo-users] Date filter problems in SqlServerSpatial 3.7
Romica Dascalescu Romica.Dascalescu at autodesk.com
Mon Nov 19 12:20:18 PST 2012
Hi Bruno,
I'm not sure why before worked, but in fact it should not work.
Since your data value is not default FDO standard date time you need to specify the format.
E.g.: DATE_1 > ToDate('2007-01-02', 'YYYY-MM-DD')
Thanks,
Romy.
________________________________________
From: fdo-users-bounces at lists.osgeo.org [fdo-users-bounces at lists.osgeo.org] on behalf of Bruno Scott [bscott at geomapgis.com]
Sent: Monday, November 19, 2012 10:30 AM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] Date filter problems in SqlServerSpatial 3.7
Hi all, since fdo 3.7 i can't filter on date.
I've digged into the debugger and find a strange behavior
The filter i'm trying to apply is
*DATE_1 > ToDate('2007-01-02')*
Internally, the provider send this to SqlServer
/CONVERT(datetime2,SUBSTRING(N'2007-01-02',8,4)+'-'+
CASE UPPER(SUBSTRING(N'2007-01-02',4,3)) WHEN
UPPER(LEFT(DATENAME(MONTH,'2000-01-01'),3))
THEN N'01' WHEN UPPER(LEFT(DATENAME(MONTH,'2000-02-01'),3))
THEN N'02' WHEN UPPER(LEFT(DATENAME(MONTH,'2000-03-01'),3))
THEN N'03' WHEN UPPER(LEFT(DATENAME(MONTH,'2000-04-01'),3))
THEN N'04' WHEN UPPER(LEFT(DATENAME(MONTH,'2000-05-01'),3))
THEN N'05' WHEN UPPER(LEFT(DATENAME(MONTH,'2000-06-01'),3))
THEN N'06' WHEN UPPER(LEFT(DATENAME(MONTH,'2000-07-01'),3))
THEN N'07' WHEN UPPER(LEFT(DATENAME(MONTH,'2000-08-01'),3))
THEN N'08' WHEN UPPER(LEFT(DATENAME(MONTH,'2000-09-01'),3))
THEN N'09' WHEN UPPER(LEFT(DATENAME(MONTH,'2000-10-01'),3))
THEN N'10' WHEN UPPER(LEFT(DATENAME(MONTH,'2000-11-01'),3))
THEN N'11' WHEN UPPER(LEFT(DATENAME(MONTH,'2000-12-01'),3))
THEN N'12' ELSE N'' END+'-'+SUBSTRING(N'2007-01-02',1,2)+
'SUBSTRING(N'2007-01-02',13,2)+':'+SUBSTRING(N'2007-01-02',16,2)+':'+SUBSTRING(N'2007-01-02',19,2)+':'+)/
This filter was working fine with Fdo 3.4,3.5 and 3.6
Someone has an idea of what's going on?
Bruno Scott
Geomap
View this message in context: http://osgeo-org.1560.n6.nabble.com/Date-filter-problems-in-SqlServerSpatial-3-7-tp5017419.html
Sent from the FDO Users mailing list archive at Nabble.com.
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users mailing list
