[fdo-users] SDF Example for Insert , Update, Read
Greg Boone greg.boone at autodesk.com
Wed Oct 10 07:49:05 PDT 2012
A simple SDF ApplySchema/Insert test (C#) can be found here:
	http://trac.osgeo.org/fdo/browser/trunk/Providers/SDF/Managed/UnitTest/ProviderTests/SchemaTests.cs
You can find other C# provider tests (for SHP access) in:
	http://trac.osgeo.org/fdo/browser/trunk/Providers/SHP/Managed/UnitTest/ProviderTests
I know they illustrate SHP file access, not SDF, but by reading these tests you can find the correct command patterns to use.
Getting back to SDF, you can find a number of C++ tests here:
http://trac.osgeo.org/fdo/browser/trunk/Providers/SDF/Src/UnitTest
Following the C# examples above, you can see how the C++ tests can be converted to C#.
Greg
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of raghulan
Sent: Tuesday, October 09, 2012 11:11 PM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] SDF Example for Insert , Update, Read
Hello Ppl,
 I am look for some some example code in C# to do the following..
I have a SDF file (created using Civil3D 2012) - which has a feature class "Pipes"
and the inside I got few proeprties such as radius, style name, etc.
There are more than one pipe (pipe names - p1, p2, p3, etc)
I am a new bee...help with this please.
I want to insert some values in the selected scheme, selected feature
class("pipes") and then identifying the row (which is pipe name = "p2") nad then in the column (Pipe radius)...
how do i do it using iinsert and iupdate command ...also how do i read a specific value
please help me with some code snippets..
View this message in context: http://osgeo-org.1560.n6.nabble.com/SDF-Example-for-Insert-Update-Read-tp5007560.html
Sent from the FDO Users mailing list archive at Nabble.com.
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users mailing list
