[fdo-users] sde 10.2
Brad Nesom kidsmake6 at msn.com
Fri Nov 1 14:28:49 PDT 2013
Are there updated fdo_sde dll files for 10.2
I don't see my instance but am able to proceed (typing the names
manually) and then get a huge long list of errors upon connect in map
2014
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance
of an object.
   at Autodesk.Gis.Map.DataConnect.UI.ArcSDEConnectionControl.SetPlugin(IDataConnectPlugin
plugin)
   at Autodesk.Gis.Map.DataConnect.UI.AcMapDataConnectUI.AttachPlugin(IDataConnectPlugin
plugin)
   at Autodesk.Gis.Map.DataConnect.UI.AcMapDataConnectUI.OnFeatureSourceNodeSelected(TreeNode
node)
   at Autodesk.Gis.Map.DataConnect.UI.AcMapDataConnectUI.treeViewDataSources_AfterSelect(Object
sender, TreeViewEventArgs e)
   at System.Windows.Forms.TreeView.TvnSelected(NMTREEVIEW* nmtv)
   at System.Windows.Forms.TreeView.WmNotify(Message& m)
   at System.Windows.Forms.TreeView.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32
msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.0.30319.18052 built by: FX45RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
Acdbmgd
    Assembly Version: 19.1.0.0
    Win32 Version: 19.1.18.0.0
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/AcdbMgd.DLL
System
    Win32 Version: 4.0.30319.18044 built by: FX45RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Core
    Win32 Version: 4.0.30319.17929 built by: FX45RTMREL
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
AdApplicationFrame
    Assembly Version: 0.0.0.0
    Win32 Version: 4.0.19.0
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/AdApplicationFrame.DLL
AdWindows
    Assembly Version: 4.0.24.0
    Win32 Version: 4.0.24.0
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/AdWindows.DLL
PresentationFramework
    Win32 Version: 4.0.30319.18060
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
WindowsBase
    Win32 Version: 4.0.30319.18060 built by: FX45RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
PresentationCore
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
System.Xaml
    Win32 Version: 4.0.30319.18015 built by: FX45RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
System.Xml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
PresentationFramework.Aero
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
System.Drawing
    Win32 Version: 4.0.30319.18021 built by: FX45RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
accoremgd
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/accoremgd.DLL
Acmgd
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/Acmgd.DLL
System.Configuration
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
AcWindows
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/AcWindows.DLL
AcCui
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/AcCui.DLL
PresentationFramework-SystemXml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll
WindowsFormsIntegration
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
AcMapRibbon
    Assembly Version: 16.1.100.47
    Win32 Version: 16.1.100.47
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/AcMapRibbon.DLL
AcWindows.resources
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/en-US/AcWindows.resources.DLL
PresentationUI
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationUI/v4.0_4.0.0.0__31bf3856ad364e35/PresentationUI.dll
System.Xml.Linq
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
    Win32 Version: 4.0.30319.18047 built by: FX45RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
PresentationFramework-SystemXmlLinq
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXmlLinq/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXmlLinq.dll
AcMapResourceManagement
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/AcMapResourceManagement.DLL
AcMapLoader
    Win32 Version:
    CodeBase: file:///d:/program%20files/autodesk/autodesk%20autocad%20map%203d%202014/acmaploader.arx
ConvertText
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/ConvertText.DLL
MapPublishImp
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/MapPublishImp.DLL
OSGeo.MapGuide.PlatformBase
    Assembly Version: 2.5.0.6139
    Win32 Version: 2.5.0.6139
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/OSGeo.MapGuide.PlatformBase.DLL
OSGeo.MapGuide.Foundation
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/OSGeo.MapGuide.Foundation.DLL
Autodesk.Map.Platform
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/Autodesk.Map.Platform.DLL
Autodesk.MapGuide.Studio.Site
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/Autodesk.MapGuide.Studio.Site.DLL
AcMapFeatureEntityTooltipsManager
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/AcMapFeatureEntityTooltipsManager.DLL
ResourceManagerRdfImp
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/ResourceManagerRdfImp.DLL
System.Data
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
System.Numerics
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
FeaturedAppsPlugin
    Assembly Version: 19.0.0.0
    Win32 Version: 19.0.55.0.0
    CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/Autodesk%20FeaturedApps.bundle/Contents/Windows/2014/FeaturedAppsPlugin.dll
AcMapInfoCenter
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/AcMapInfoCenter.DLL
AcWorkspaceSelector
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/bin/AcWorkspaceSelector.DLL
ManagedMC3
    Assembly Version: 7.2.0.0
    Win32 Version: 7.2.0.0
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/ManagedMC3.DLL
AeciRibbon57Res
    Assembly Version: 17.2.1.0
    CodeBase: file:///D:/Program%20Files/Autodesk/AutoCAD%20Raster%20Design%202014/AeciRibbon57Res.dll
Autodesk.Map.IM.FeatureSearch
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/bin/Autodesk.Map.IM.FeatureSearch.DLL
Autodesk.Map.IM.Genuine
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/bin/Autodesk.Map.IM.Genuine.DLL
Autodesk.Map.IM.Forms
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/bin/Autodesk.Map.IM.Forms.DLL
Autodesk.Map.IM.Map
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/bin/Autodesk.Map.IM.Map.DLL
Autodesk.Map.IM.PlugInHandler
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/bin/Autodesk.Map.IM.PlugInHandler.DLL
Autodesk.Map.IM.ImageResources
    Assembly Version: 16.0.14.2
    Win32 Version: 16.0.014.2
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/bin/Autodesk.Map.IM.ImageResources.DLL
Autodesk.Map.IM.Loader
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/bin/Autodesk.Map.IM.Loader.DLL
log4net
    Assembly Version: 1.2.11.0
    Win32 Version: 1.2.11.0
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/bin/log4net.DLL
Autodesk.Map.IM.Config
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/bin/Autodesk.Map.IM.Config.DLL
Autodesk.Map.IM.Logging
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/bin/Autodesk.Map.IM.Logging.DLL
Autodesk.Map.IM.ExceptionDialog
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/bin/Autodesk.Map.IM.ExceptionDialog.DLL
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/bin/Autodesk.Map.IM.Exception.DLL
Autodesk.Map.IM.Services
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/bin/Autodesk.Map.IM.Services.DLL
Autodesk.Map.IM.Collections
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/bin/Autodesk.Map.IM.Collections.DLL
Autodesk.Map.IM.FeatureServiceListener
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/bin/Autodesk.Map.IM.FeatureServiceListener.DLL
Autodesk.Map.IM.Tools
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/bin/Autodesk.Map.IM.Tools.DLL
OSGeo.MapGuide.Geometry
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/OSGeo.MapGuide.Geometry.DLL
ManagedInternal
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/ManagedInternal.DLL
Autodesk.Map.IM.GwsInterface
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/bin/Autodesk.Map.IM.GwsInterface.DLL
ManagedMapApi
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/ManagedMapApi.DLL
Autodesk.Map.IM
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/bin/Autodesk.Map.IM.DLL
Autodesk.Map.IM.Data
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/bin/Autodesk.Map.IM.Data.DLL
Autodesk.Map.IM.Graphic
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/bin/Autodesk.Map.IM.Graphic.DLL
Autodesk.Map.IM.CoordinateSystem.API
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/bin/Autodesk.Map.IM.CoordinateSystem.API.DLL
Autodesk.Map.IM.Data.UnitSupport
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/bin/Autodesk.Map.IM.Data.UnitSupport.DLL
Autodesk.Map.IM.CIP.Waypoints
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/bin/Autodesk.Map.IM.CIP.Waypoints.DLL
Autodesk.Map.IM.CoordinateSystem.Factory
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/bin/Autodesk.Map.IM.CoordinateSystem.Factory.DLL
Autodesk.Map.IM.CoordinateSystem.MapGuideApi
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/bin/Autodesk.Map.IM.CoordinateSystem.MapGuideApi.DLL
Autodesk.IDM.Embedded
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/bin/Autodesk.IDM.Embedded.DLL
Autodesk.IDM.AutoCADEmbedded
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/bin/Autodesk.IDM.AutoCADEmbedded.DLL
Autodesk.Map.IM.MapToAcad.UI
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/bin/Autodesk.Map.IM.MapToAcad.UI.DLL
Autodesk.Map.IM.RibbonItems
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/bin/Autodesk.Map.IM.RibbonItems.DLL
Autodesk.Map.IM.Display.GraphicsGeneration
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/bin/Autodesk.Map.IM.Display.GraphicsGeneration.DLL
AcAeNet.resources
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/en-US/AcAeNet.resources.DLL
AcButterflyExt.resources
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/en-US/AcButterflyExt.resources.DLL
AcCloudRender.resources
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/en-US/AcCloudRender.resources.DLL
AcCustomize.resources
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/en-US/AcCustomize.resources.DLL
AcDxWizard.resources
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/en-US/AcDxWizard.resources.DLL
AcExportLayoutUI.resources
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/en-US/AcExportLayoutUI.resources.DLL
AcInterfere.resources
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/en-US/AcInterfere.resources.DLL
AcLayer.resources
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/en-US/AcLayer.resources.DLL
AcLayerTools.resources
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/en-US/AcLayerTools.resources.DLL
AcMrUi.resources
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/en-US/AcMrUi.resources.DLL
AcMultiLineUi.resources
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/en-US/AcMultiLineUi.resources.DLL
AcRecoverAll.resources
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/en-US/AcRecoverAll.resources.DLL
AcScaleList.resources
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/en-US/AcScaleList.resources.DLL
AcUnderlay.resources
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/en-US/AcUnderlay.resources.DLL
AcViewTransitionsUi.resources
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/en-US/AcViewTransitionsUi.resources.DLL
AdskConnectionPointMgd.resources
    Assembly Version: 1.0.0.0
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/en-US/AdskConnectionPointMgd.resources.DLL
AcCalcUi.resources
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/en-US/AcCalcUi.resources.DLL
AcMapDataConnectUI
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/AcMapDataConnectUI.DLL
OSGeo.FDO
    Assembly Version: 3.8.3046.0
    Win32 Version: 3.8.0.0
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/bin/FDO/OSGeo.FDO.DLL
PresentationFramework-SystemData
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemData/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemData.dll
UIAutomationTypes
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll
PresentationFramework-SystemCore
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemCore/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemCore.dll
Accessibility
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
AcMr
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/AcMr.DLL
System.Runtime.Serialization
    Win32 Version: 4.0.30319.18055 built by: FX45RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
OSGeo.FDO.Common
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/bin/FDO/OSGeo.FDO.Common.DLL
Autodesk.Gis.Plugins
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/Autodesk.Gis.Plugins.DLL
AcMapDataConnectPlugins
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/AcMapDataConnectPlugins.DLL
ArcGISDataConnectPlugin
    Win32 Version: 1.0.0.0
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/Plugins/DataConnect/ArcGisDataConnectPlugin.dll
Autodesk.Map.IM.DataConnect
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/Plugins/DataConnect/Autodesk.Map.IM.DataConnect.dll
AcLivePreviewContext
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/AcWindows.dll
AcCustomize
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/AcCustomize.DLL
AcLayer
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/AcLayer.DLL
UIAutomationProvider
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
AcMapManagedUIForms
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/AcMapManagedUIForms.DLL
System.Data.DataSetExtensions
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Data.DataSetExtensions/v4.0_4.0.0.0__b77a5c561934e089/System.Data.DataSetExtensions.dll
Autodesk.Map.GeoSpatialManager.MergeTool
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/Autodesk.Map.GeoSpatialManager.MergeTool.DLL
Autodesk.Map.IM.Settings
    CodeBase: file:///D:/Program%20Files/Autodesk/Autodesk%20AutoCAD%20Map%203D%202014/bin/Autodesk.Map.IM.Settings.DLL
************** JIT Debugging **************
Application does not support Windows Forms just-in-time (JIT)
debugging. Contact the application author for more
information.
More information about the fdo-users mailing list
