[fdo-users] FDO OGR 4.1 still has problems with Latin1/ISO-8859-1 when using MapInfo TAB
Hans Milling hm at geograf.dk
Fri Oct 7 05:41:53 PDT 2016
Here is a test mapinfo file if you want to add to MapGuide and see for
yourself or run some other test:
http://www.geograf.com/filer/names.zip
The problem existed since 2012 (and before) in all versions of the OGR
provider.
The coordinate system used by the TAB file is EUREF89 UTM 32N (EPSG:25832)
View this message in context: http://osgeo-org.1560.x6.nabble.com/FDO-OGR-4-1-still-has-problems-with-Latin1-ISO-8859-1-when-using-MapInfo-TAB-tp5289710p5289786.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
