[FOSS-GPS] High accuracy positioning with low cost GPS devices:a FOSS project
Abdelrazak Younes younes.abdel at gmail.com
Fri Oct 17 02:56:55 EDT 2008
Hello John,
On 10/10/2008 19:37, John Morris wrote:
> I did a zero baseline test with the LEA-4T, and the carrier phase looked
> pretty good. The LEA-4T needs some interpolation tricks to get things to
> work.
What do you mean by 'interpolation tricks'? Do you make use of future
measurements in order to help cycle slip detection? I am using a very
simple cycle slip detector based on range rate step detection (I've put
the deytection threshold to 6 m/s²). In the future I'd like to switch to
a sequential algorithm (cusum). I'd like to keep my code working in
real-time but, considering that I am working with 10Hz raw data, I guess
I can afford waiting a couple of sample before using the carrier phase...
In my experience, the carrier phase is starting to be usable with a CNO
of 36dBHz in static positioning mode. By 'usable', I mean no cycle slips
every three seconds. And I found that the accuracy is not very good,
about 10cm/s (one sigma) at 40dBHz. With dynamic positionning in a urban
environment, things are much, much worse...
I'd like to hear about your experience. My goal is to have the best
possible standalone navigation solution (including SBAS). Right now I
manage to get a position that is better than the LEA-4T but not by a big
margin.
>   The other inexpensive receiver is Thales AC-12. This one provides
> carrier phase within a couple mm. My understanding it is the same GPS engine
> which is used in the Promark II for doing single frequency RTK. (BTW, is
> there a cheaper LEA-4T than the u-blox demo unit?)
Don't know, maybe in the Chinese or Taiwanese market.
Abdel.
More information about the FOSS-GPS mailing list
