[FOSS-GPS] High accuracy positioning with low cost GPSdevices:a FOSS project
Tomoji Takasu ttaka at yk.rim.or.jp
Mon May 18 00:44:01 EDT 2009
Hellow, Stefan
Thank you for using RTKLIB.
> Data format: RTCM 3.0 :
> 1004(1),1006(10),1008(10),1012(1),1019(120),1020(60)
> " # of Input Data Base/NRTK-Station:
> Obs(0),Nav(62),Ion(0),Sbs(0),Pos(50),Dgps(0),Err(0) "
It seems that RTCM 3 type 1004 messages are not recognized.
(but type 1006 and 1019 are OK)
Would you save the NRTK stream to the File using Log Streams
dialog and send it to the following support email address.
I will check it.
rtklib_support at gpspp.sakura.ne.jp
Best regards,
T.Takasu
----- Original Message -----
To: <foss-gps at lists.osgeo.org>
Sent: Sunday, May 17, 2009 8:44 PM
Subject: Re: [FOSS-GPS] High accuracy positioning with low cost GPSdevices:a
FOSS project
> Hello T.Takasu,
> thanks for the new RTKLIB-release!
> I have made initial trials and have a question about the use of the
> RTCM-streams:
> My equipment:
> Rover: u-blox-receiver
> RTCM-stream:
> WTZR0
> Broadcaster: www.euref-ip.net
> Location: Bad Koetzting, Germany
> Operated by: BKG
> Receiver type: LEICA GRX1200GGPRO (GPS+GLO)
> More info at:
> http://www.epncb.oma.be/_trackingnetwork/siteinfo4onestation.php?station=WTZR_14201M010
> In RTK-Monitor i always get the "ERROR/WARNING"-message: "no base-station
> observation data"
> and in the line:
> Nav and Pos count up, but Obs does not.
> Where i m doing wrong?
> Thank you for your help.
> Stefan
> http://n2.nabble.com/High-accuracy-positioning-with-low-cost-GPS-devices%3A-a-FOSS-project-tp1312818p2915935.html
> Sent from the Open Source GPS-related discussion and support mailing list
> archive at Nabble.com.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS mailing list
